That is very odd. I've been in the hearth business for 15 years and have never been faced with this problem. Although, I suspect the remote receiver box is the is the culprit. To test this theory, turn the receiver box OFF. If you're unable to do that, remove the batteries from the receiver box and try operating the stove manually. If it then operates manually, it may be the reciever is wired incorrectly or the 3 position rocker switch on the stove, needs to be switched from Remote to ON. That would then override the remote receiver.
Hope this helps you and thanks for choosing FixYa.
Thank you I have not tried this yet. I will. If this doesn't work where can I get a thermacouple
the pilot will start but not stay lit kind of sounds like a thermacouple.
Sorry it took 6 days to get back to you. We were in hurricane Irene's path and just got our internet service back, after one week. It may not be the thermocouple. The Oxygen Depletion Sensor (ODS) , which is part of the pilot assembly may be clogged. In which case, it's reading not enough oxygen for safe combustion. Is it is the thermocouple, if I recall correctly, your model has a stand alone thermocouple. Which is pretty standard for the old Vanguard Vent-free Gas appliances and many other models. A & B Sales http://www.aandbsales.com/ I have also included a link to your Owner's Manual, in case you have misplaced yours.http://www.worldmkting.com/documents/SSU...
I hope this has helped helped you.
