SOURCE: ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
SOURCE: Have an SBG6580 and purchased a NETTALK DUO
The only way I got the NETTALK DUO to work keeping my SBG6580 is to use it in cascading mode with my old Linksys router. When I plugged the DUO into the Linksys it worked great.
Testimonial: "Your solution worked!!! I took your advice and bought a router that is on NetTalks list of compatible routers. It worked instantly!"
SOURCE: How do I setup to use the dual band feature on the
Contact your Internet Service Provider. Since you will be connecting your modem to their network, you need to follow their setup instructions, to ensure that it functions correctly.
Your wireless is set up with a password. You need to get that password before you can connect any more devices. From a computer that can connect to the internet go to 192.168.0.1. Then type admin for the username and motorola for the password. I believe from there you click Wireless then click Primary Network. You should see your wireless network name and password from there. I'm getting this from the modems manual here: http://www.midcocomm.com/_files/files/SBG6580.pdf
