SOURCE: Asus Eee PC wireless connection pending
You may be choosing the wrong encryption method. For instance your entering your wireless key (WEP) and you have it set on (PSA, WPA). Make sure those settings match. Also you may have an IP conflict which is resolved by setting up a static ip. If the encryption methods match and you need help with a static IP let me know
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
SOURCE: ASUS keyboard delete key won't work
are you sure that the key is seated properly on the board? This can easily be fixed by popping it off and checking to see if the 1, or 2, plastic like springs are connect to the key and the board.
SOURCE: Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
SOURCE: problem with internet connection
Check both your router and your PC configurations. Follow the manufacturer's directions for configuring your router and PC for WiFi access.
