SOURCE: Fax Jam
hp tells me to do the following
does this help you ?
Issue
While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur.
Clearing paper jams
Remove the jammed paper by following the steps below:
WARNING:
Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
Preventing paper jams
The following information will help prevent paper jams from occurring:
richard from chicago
SOURCE: Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
SOURCE: faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters
Information
It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured.
From the front panel:
The screen will read Cfg param val: 26
Screen will read Test -001+
SOURCE: MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
