Please do the following.
1. If you have changed the default password you will have to reset router and the password will be set to the default password. To reset the router to factory default keep the reset button pressed for 15 seconds while the router is powered on the reset button is located on the back of the router inside a small hole which needs to be pressed using some pointed object like a pen or a pin.
NOTE** its importaint to note that if you reset the router to factory defaults you will lose all the configuration and you will have to reconfigure the router***
2. if you have not reset/ changed the password ever try using the following user name and password
username password
admin admin
system admin
root root
admin
System
root
