Canon 75-300mm f/4-5.6 III USM EF Lens Logo
Question about Canon 75-300mm f/4-5.6 III USM EF Lens
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing sound. It will not focus closeup at all. If I switch to manual, it still does not focus correctly. I have two other canon lenses which work fine when attched.
Posted by info82885 on
suresh Kulkarni
    New Friend:
  • 51 Answers
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Posted on Oct 01, 2017
5 Related Answers
Anonymous
SOURCE: Camera won't shoot with lens on Auto Focus
Talked to canon support, they suggested to send lense in for review/repair. They said it could be the motor, I think it was a gear problem based on the noises and jerkiness of the focusing action while in manual focus (manual focus gave out as well). Cost TBD - "would definately be more than $50. I shopped around and elected to buy a new lense rather than try to hassle with the repair, shipping, insurance, and the wait, etc. Besides, I have a deadline that I need the lense for, so repair at Canon really became a non-option. I think the cost would've been pretty much the same in the end as the new lense, since this wasn't one of the costlier of lenses to begin with.
Posted on Mar 20, 2008
Anonymous
SOURCE: My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Posted on Dec 26, 2008
Anonymous
  • 667 Answers
SOURCE: EF-S 17-85mm will not auto focus on fuul zoom my
A dirty filter or smudges/marks on the optics, especially the rear element can cause focus issues. Cleaning the pins contacts on the mount of the lens can be a simple solution too. Beyond that, circuit replacement is the next likely step.
Posted on Jun 06, 2009
Anonymous
  • 30 Answers
SOURCE: my canon eos rebel xt 350d wont focus
change your manual settings
Posted on Oct 11, 2009
Anonymous
  • 421 Answers
SOURCE: Canon EF 75-300mm f/4-5.6 III USM Lens
If your AF motor is hunting then the lens probably needs to be looked at. I wouldn't recommend this as something to do at home so you will need to either find a repair shop if it is out of warranty or return it to Canon if it is in warranty.
Posted on Jan 17, 2010
Auto focus does not work on canon eos 300d camera
It may be that the ribbon connector has broken in the lens.
1helpful
I have a Canon 100mm macro lens used on a Canon EOS 40D Camera. The problem I have is that the images produced seem to be not pin sharp, even when using a tripod and the mirror lockup function on the...
It seems that you have either a faulty lens or one which is performing outside of the minimum quality standards. You have clearly done everything possible to try and eliminate all other causes. Looking at the firmware updates for your camera, none of them mention an issue involving your lens but you may wish to ensure that you have the latest firmware anyway.
All you can do is to contact Canon customer care to request that the lens is exchanged.
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
1helpful
I have a Cosina AF Macro 100mm lens that I used on
you should be able to use that lens with it. As long as it attaches to the SLR body ok. The thing to be aware of is with better technology in the newer camera you may have AF issues with that particular lens.
1helpful
Need Help, the auto focus of my canon 400D won't work.(I can still shot with manual focus)
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
2answers
Would this lens work with my digital canon xs?Sigma 70-300mm f/4-5.6 Macro AF zoom lens for Canon EF film cameras
yes ef stands for electric focus which is what your camera mounting should be check your mounting to make sure its EF and if it is go for it. also the mounting type might be in your hand book
Would a canon 100mm f2.8 be a lense to use to shot a basketball game sitting under the goal?
Well it could be used but you may find the auto focus to be too slow and the aperture of f2.8 a bit dark for indoor sports. That lens is best used in the role it was intended — macro photography. Take a look at the 85mm f1.8 USM or the 100 f2 USM. They are reasonably priced and offer greater AF speed and low light ability.
Hope this helps
2answers
Canon rebel xti focus issues
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
2answers
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
