Hi call pride mobility 61 3 8770-9600 or email [email protected]
SOURCE: My go go elite Scooter will not work.
It may still be under warranty. What kind of reading did you get from the batteries? If they are below 12.0 volts they may have a poor memory. If you leave a chair un-charged for a long period of time the batteries can discharge to a very low level. The charger cannot bring a battery up from 11 voltsDC. You will need a slow car type charger or new batteries.
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
SOURCE: AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
SOURCE: i have a go-go elite traveller scooter and the
if light does not work fault in wiring or connection
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
