Here is what the F5 error code is, i copied and pasted this from my duet (online) service manual
F/05
Water temp. sensor failure
if during the water heating step in wash cycle,the water temp. sensor (NTC) value is out of range,or heating circuit has failed,the "F/05" error code will be displayed
- Check the water temp.sensor,heat element,and element relay.
-Check connections to the sensor,heating element, and relay
So what that says is the water heated too high of a temp. and the thermostat is bad, the heating relay on the control board is bad,or heat element is shorted and heating when not supposed to.
Good luck,while i always advicate people trying to fix their own stuff, if this sounds over your head call for service,
GENE
