Question about HP iPAQ hx2790 Pocket PC
I have a HP Ipaq 2490. It was working fine until a couple of days ago. First it wouldn't turn on, then finally it came on with a white screen. I did a hard reset and came back up. I went to install a program on it and it went back to white screen and won't do anything now. Any suggestions? I use this for work frequently. Thank you!!
Posted by pronspect1 on
Larry Ng
  • HP Master
  • 6,015 Answers
I just cried a river for you,
If I saw it in a garage sale for $1 id buy it and crush it so others
cant suffer like you, no really.
batteries inside both are gone, some are solder in too.
opps.
what good is this thing in 2017? tell me love to hear it.
buy used smart phone that has support.
why not ask HP, we are not.
ask them and hear load laughter,,or worse.
sorry but all ours are in the landfill making bad ground water.
https://h30434.www3.hp.com/
Posted on Oct 13, 2017
5 Related Answers
Anonymous
  • 450 Answers
SOURCE: my iPAQ will not charge or turn on ...
Can you get the iPaq hooked up directly to AC power? There's apparently a charging threshhold for badly depleted batteries that the USB port cannot get over.
Posted on Sep 08, 2005
Anonymous
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
Anonymous
  • 36 Answers
SOURCE: Ipaq 2490 hangs on booting
Try this:
4. Make clean reset (hold callendar + itask, then press and hold reset), after about two seconds you will hear knack. Now unhold these buttons. The screen will be black.
5. After that make hard reset (hold callendar + messaging + power and then press and hold reset) after about two seconds unhold reset button first and after about one seconds remaining buttons. You will see on screen PS FORMAT.
6. Now is you iPAQ ready.
Posted on Feb 22, 2009
SOURCE: when I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Posted on Jan 06, 2010
Anonymous
SOURCE: Ipaq h4150 failed rom upgrade (white Screen)
Pull the battery out, wiat for a minute and reinstall the battery and turn it on.
Posted on Mar 28, 2010
When I connet the Ipaq 2490, teh screen lights up
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Screen is locked
Mine hp ipaq also froze up, but I tapped the screen until they moved around all in alignment, and I got the basic things back (my programs, Media Player etc. but I can't sync it with my computer. It doesn't recognize the name of my handheld.
Aug 04, 2008 | HP iPAQ HX2755 Pocket PC
Align problem
ask hp , this thing is old.
ever heard of HP.?
and there support forum. seems not.
Jul 11, 2017 | HP iPAQ RX1710 Pocket PC
IPAQ H2210
yes I replaced the battery a couple of days ago.the align screen is frozen
Feb 23, 2008 | HP iPAQ H2210 Pocket PC
Try this:
Nov 24, 2007 | Computers & Internet
IPaq rx3715 locked up
try leaving battery out overnight.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ  hx2790 Pocket PC Logo
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
