Question about Dell Dimension 4700 PC Desktop
Dell 4700 wont boot up - Dell Dimension 4700 PC Desktop
    Novelist:
  • 182 Answers
To boot up:
1.Restart Your computer Press Delete until BIOS setup appears.
2.Go to Advance BIOS setup then Boot sequence.
3.First Boot Your CD-Rom, 2nd Boot the HDD-0.
4.Save The Settings Then restart.
5)when appear "press any key to boot" then click ENTER button of your keyboard it will automatically boot.
Posted on Aug 17, 2011
6ya staff
SOURCE:
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
Dell 4700 power up to desk top then shuts down
check your cpu fan if still working. if it is working try to edit your bios to safe defaults and save it then boot up. also try to boot on safe mode if it is ok in safe mode then try system restore...if worst.. format your pc
Aug 10, 2012 | Dell Dimension 4700 PC Desktop
Replaced 80gb with 500gb sata wd green also have 500gb sata as second drive bios level 10 sees both in setup but nothing is available in boot including well used cd drive- system dell dimension 4700- any...
Did you remember to set one drive as a master and the other as a slave driver?
To do so. Removed the drive and look on either the front or back and it'll give you the jumper set up.
Master is the primary boot drive and the slave will the be media, documents drive
Aug 22, 2011 | Dell Dimension 4700 PC Desktop
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Dimension 4700 how do I fully restore computer to original setup
To restore your dell pc you put in the restore disk that came with the pc and reboot the pc. It will tell you to press any key to boot from the cd. After pushing any key it will begin to boot from the cd and reinstall windows just as it was from the factory. Depending on the operating system the restore cd will look something like this.
Apr 29, 2010 | Dell Dimension 4700 PC Desktop
Dell 4700 desktop, will not boot up. Light remains
A solid Amber power LED is an indication of a motherboard problem. Remove any external connections and see if LED indications change. If no change, remove all PCI expansion cards, try again. If still no go, disconnect all drives, try again. If still no change, ensure the CPU heatsink is firmly attached (If loose you need to replace the retention module) If nothing loose and no changes from other steps, replace motherboard
Mar 11, 2010 | Dell Dimension 4600C PC Desktop
I have a Dimension 4700 and it will not boot more than half the time. So I did a clean OS install and drivers, updated everything and it was working great. Tried to turn it on this morning and the same...
If you have a Dell, then do this the next time.
As soon as you see your system creating problems again, turn to the back of the computer. There are 4 LED lights. See the status of those lights, I mean, green, orange etc. Check it on support.dell.com and see if you find something useful.
Nov 02, 2009 | Dell Dimension 4700 PC Desktop
Beeps, wont boot up
Most of the time when it beeps, and there is nothing show on the computer screen, it is a RAM problem. A stick of ram may have gone bad. If you have two sticks of ram in the computer, you can try to remove one stick at a time to see which one might have gone bad.
Mar 23, 2009 | Dell Dimension 4700 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
227 people viewed this question
Ekse
Clive
Clive
Alun Cox
