Question about Refrigerators
The contents of the refrigerator freeze even on low settings
Posted by banks_graham on
Josefina Agulay
    Novelist:
  • 78 Answers
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Posted on Sep 04, 2011
MarbleWinner
  • 3 Answers
Hmm. have you tried talking to a pro appliance tech over the phone. I know the guys over at appliancerepairmodesto.com know their stuff well. Best of luck!
Posted on Jan 31, 2020
I have a true double door commercial refrigerator. it stay below freezing even though I set the temperature very low. it is freezing everything.
thermostats on those things are notoriously bad. probably a bad thermostat. should have numbers 1 - 9 and usually set on 5
Aug 18, 2013 | True Refrigerators
Foods freeze on the vegetable bin even the control was set very low
Hi,There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 04, 2011 | Microwave Ovens
I have a Goldstar small refrigerator GR-151SPF which is presently freezing the contents. Please tell me if high or low numbers make the frig colder. Thank you.
Hi and welcome to FixYa, I am Kelly,
Warmest settings are CCW and COLDER settings are clockwise on the control. Use the numbers as a reference point but... CCW = warmer Clockwise = COLDER
Thanks for choosing FixYa,
Kelly
Feb 25, 2011 | Goldstar Refrigerators
Food on the top shelf and in the bottom drawer keeps freezing
I'd check the temp control and up the temp abit instead maybe you have it all the way down low at the lowest setting, that will cause the contents to freeze.
Feb 03, 2010 | Viking 42 in Built In Professional...
Our n180 keeps freezing all fridge contents milk,olives ??? we had habitation check in july
only one thing that can do this.. your thermostat.. its either broken or set to low
Nov 11, 2009 | Thetford Norcold N323 1.7-cu ft 3-way...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Food gets frozen
If your refrigerator freezes its contents, even when the cold control is set to its lowest setting, its cold control is probably defective. Call an appliance repairperson. As a rule, refrigerators are designed to maintain 37 to 40 degrees F in the refrigerator box and 0 to 5 degrees F in the freezer box. Setting either compartment to lower temperatures generally costs you extra in energy dollars. If the icemaker keeps making ice, even when full: 1) Lift the bail wire to shut it off. 2) Empty the bin, remove the icemaker, clean it, and reinstall it. 3) If the problem persists, consider having an appliance repairperson remove and replace the entire icemaker and valve, a relatively affordable repair. With this type of problem, it's often better to replace the unit rather than to pay for
Jan 18, 2006 | Hoover HCA331FFK
Refrigerators Logo
365 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
