Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
1 year old kitchenaid kbfs25etss01. all of a sudden the fridge temp is up to 55 degrees. i did put a bunch of water, soda and beer in the fridge tonight. is it blocking something? door seems shut.
Posted by Bill Judd on
Gere knutson
  • KitchenAid Master
  • 842 Answers
Watch the unit for at least a hour, to see if the temps drop. You could have had the door open too long and lost a lot of air. Normally, they can recover from this, and this is nothing to worry about. I loaded my today also and my temps went up to 45, but my door way open for about 10 mins or so. Don't check the unit for at least 1 hour. Allow time for the system to recover. It should be ok. It should be able to drop temps with in a hour or a least 10 degrees.
Get back to me if you have any more question or concerns.
Good Luck, enjoy your cold beer....
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Aug 17, 2011
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
4 year old kitchenaid kbfs25etss01 inside lights stopped working. Bulbs are good. what could the problem be?
Locate the door switch. This is more than likely the problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 06, 2012 | KitchenAid Refrigerators
I have a mini red bull fridge...
Open up the compressor area and trace the wiring. The thermostat should be indicated on the wiring diagram, which should be pasted on the cabinet.
It just may not be obvious without a conventional knob, but it will have a thermal sensor tube- usually copper. It might be bonded on a sheetmetal panel inside the fridge. at least one wire to the compressor's mag starter will be attached to that thermostat to interupt power. It would be adjustable with a small flat bladed screwdriver. Clockwise should lower the temperature, and counter clockwise should raise it. To further complicate it that adjustment screw may be under a dab of red paint that used to anchor it.
Put a thermometer in the fridge to monitor the temp. While water will freeze at temps below zero, Sodas will not normally develop ice until below 30 degrees F and and beer will be fine to about 15 degrees F before it freezes.
Apr 02, 2012 | Refrigerators
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
My light works but the motor won't kick on, Frigidair top freezer
THE CURCUIT BOARD IS NOT SENDING A SIGNAL TO YOUR MOTOR WHICH ENABLES YOUR MOTOR TO KEEP THE VALUBLE CONTENTS IN YOUR FRIDGE COLD...(BEER) EVERY MANS FAVOURITE HOBBY...CHECK YOUR CIRCUIT BOARD FOR CORROSION OR DAMAGE...HOPE THIS HELPS...IF SO SEND ME A COLD ONE
Dec 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
Beer not getting cold
Try cleaning the coolers condenser core.
Jul 06, 2017 | Frigidaire PLKU1267DS Stainless Steel...
Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Oct 03, 2008 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
402 people viewed this question
Top KitchenAid Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
