Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
Document jams in the ADF (Document Tray)
- Press <Stop/Reset>.
- If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
- Remove the jammed page from under the roller to the Feeder Cover side.
- Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
- After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
- Close the Feeder Cover.
Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
When rescanning the document after clearing the error, rescan it from the first page.
Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass.
- If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
- When rescanning the document after clearing the error, rescan it from the first page.
- Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
- Open the Document Cover and pull out the document from the inner side.
- Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
Trust this is helpful. Please vote. :)
