Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire. If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
You've found the right place buddy
I keep buying manuals from various websites so I can damn well help u in this..
what chipper is it btw? Like few websites have some manuals better while some have other brands better
There's a website
that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help
thanks
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
