Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive Logo
Question about Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive
I've been noticing a squeaking sound intermittently
Posted by Joseph Murphy on
Anonymous
    New Friend:
  • 88 Answers
Good day,i think the problem would be you hard disk sir,better to change a new one.tnx
Posted on Aug 17, 2011
Intermittent headlight bulb
DEFINITLEY SOUNDS LIKE WIRING PROBLEM
06 Elantra squeaking/rubbing front wheel
if your car is front wheel drive it could be your cvs that go to the trans,do you have the orginal tires on it or did you put bigger ones ? didyou do any changes/ then this noise started.thats the best I can do without me looking at it.
My camaro squeaks really loud whenever i turn the steering the wheel left or right whether I'm moving or sitting still. It sounds like it's coming from both sides of the front end.
tie rod ends dry? this kind of thing is easily found if one person moves the wheel and the other listens and/or feels the different front end components. loud squeaks are generally accompanied by vibration which is hard to miss if you get down close to it.
Squeak
Could be belt itself and/ alternator pulley. Hope this helps
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Squeaky front end saturn vue
Worn control arm bushings, worn stabilizer bar end links or bushings. Worn strut mounts. Worn ball joints, worn tie rod ends (less likely)
1helpful
2001 T&C LXi - front blower fan is working intermittently
Hello! to answer your question; No...The intermittent operation is more than likely being caused by loose or oxidized contacts in the motor connector plug...Blower motor switch connector or the blower motor resistor plug...go to Radio Shack and purchase a product called DeOxit...cost $15...It's a two spray can package...A cleaner and contact protector spray...Cans are small you do not need much...Spray all three plugs; both male and female pins...You will notice a bubbling action...No wiping off...This is a no touch spray...This should clear up the problem...On the blower switch plug is a Black/Orange wire which goes to ground...Using an ohmmeter check this wire for zero ohms to ground...On the X10 scale...If you do not read zero ohms...The connection of this wire needs to go to bare metal chassis ground...
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
My 04 trailblazer intermittently sounds like it is running over a rumble strip, then it stops after applying brakes a few times
What would a "rumble strip" sound like? Squeaking, metal clanking against metal? Trailblazers have lots of noises that are a nuisance, and I've fixed most of them.
Top Seagate Computers & Internet Experts
Steve
Mehandi Husain ...
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
