Question about Bunn VPR Coffee Maker
Bunn Coffee Maker VPR - should we put vinegar in the reservoir and run it though - of should we just put a little vinegar in with some water? We ordered a de-liming spring tool and we will use it when we receive it. Should we still try to clean the resevoir, and if so, before or after using the de-liming spring tool?
Posted by anne_sullin on
Mike Cairns
  • 3,053 Answers
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Posted on Oct 23, 2011
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
How can I clean the inside of the tank?
mix a little vinegar in the water and run it through the tank several times like you are making coffee, then run clean water till all the vinegar it out.
Aug 18, 2011 | Bunn VPR Coffee Maker
The nurses use the Bunn VPR 2 burner coffee maker. They have succeeded in having horrible hard water residue all around the outside of the pour area. Vinegar doesn't seem to clean it off. What would...
This can be solved by running vinegar and water through unit and here is more information.
Jun 16, 2011 | Bunn VPR Coffee Maker
Coffee tastes funny. does machine need to be cleaned?
Yes, in this type of machine, put a little bit of vinegar and water in top and run a couple times through machine, with of course filter basket on, not with filter or coffee, and brew a couple times. Use 25percent to water ratio, do this twice then do it again, twice with only mineral water. Then make a pot normal, and let me know how coffee taste now. Thanks Mr Bean Man
Jun 09, 2011 | Bunn VPR Coffee Maker
Just bought the a new Bunn VPR with two heaters for work. Should the unit be unplugged at night? If it is unplugged, how long the next day will it take to brew a pot. Is it safe to leave the unit...
That is one of the best coffee makers ever.It will last for a long time.Yes it is ok to leave it unplugged.Do not ever leave an empty pot on a burner that is on.Once a month,put 1 cup of white vinegar where the water goes,and run the machine.This will clean the inside.After you use the vinegar,run one pot of clean water through the machine.
May 13, 2011 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
Apr 13, 2010 | Bunn VPR Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
669 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
