Question about Lexmark X544n All-In-One Laser Printer
Lexmark x544 108.02 printhead error - Lexmark X544n All-In-One Laser Printer
Posted by glenn t steffenhagen on
Sanath Kumar V
  • Lexmark Master
  • 684 Answers
1. Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return?
Yes: Continue to Step 2.No: Print a test page. If the page prints, the printer is working correctly.
If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.Did the error message return?
Yes: Contact Lexmark @ 1-800-(539-6275) No: Print a test page. If the page prints, the printer is functioning correctly.
Posted on Sep 17, 2011
3 Related Answers
Deepali Pandit
  • 68 Answers
SOURCE: how to fix 108 service printhead error on c762
Hello, Please try this: Power off the printer, take the Color cartridge out(Magenta), take a thin and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. Try again to print this will help.
Posted on Mar 19, 2010
wyomork
Tim Morkemo
  • 3 Answers
SOURCE: Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Posted on Apr 27, 2009
Anonymous
  • 300 Answers
SOURCE: Lexmark Colour C752 108 service printhead error
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
“RIP Board” on page 4-11
If this does not fix the problem replace:
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the “Printhead Adjustments” on page 4-1.
Posted on Jun 03, 2008
Printhead error on a lexmark pro901
The printhead needs to be replaced. If your printer is still under warranty, contact our technical support team so that we can replace your printhead. If not, you can purchase a printhead online at http://bit.ly/IZYhWo
Sep 17, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
There's a problem with the printhead
Try this approach to fix the printhead problem:1. Open the printer cover > remove the ink tanks > open the printhead latch > remove the printhead > close the printhead latch.2. Visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.3. After the update is successful, open the printer cover > open the printhead latch > re-install the printhead > close the printer cover > if no error appears, continue with normal installation steps for cartridges. If error still appears, try to remove and re-insert the printhead firmly.
4. Try to print again to verify that the problem is fixed.
Should the error persist, it could be that the printhead itself is faulty. If that's the case, please contact Lexmark Technical Support for further assistance.
Feb 08, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Message on screen printer printhead error
A firmware update addresses printhead error problem on recent Lexmark printers. Please visit the Lexmark website to download and install the Lexmark Firmware Update . Select your corresponding model to start the download.
Should the error continue to display on your printer, please contact Lexmark Technical Support Center for further assistance.
Dec 31, 2011 | Lexmark X Office Equipment & Supplies
There is a problem with the pinterhead please help its a lexmark pro705
A firmware update for the Lexmark Prevail Pro705 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  1. Open the printer cover and remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened. Remove the ink tanks > open the printhead latch and remove the printhead > close the printhead latch, close the printer cover and confirm the error message goes away from the operator panel.
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Dec 11, 2011 | Lexmark X5650 All-in-One InkJet Printer
Printhead is not supported by the all in one
A firmware update for the Lexmark Prospect Pro205 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer cover. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Oct 06, 2011 | Lexmark Prospect Pro205 Wireless...
"there is a problem with the printhead"
Sounds like you need a new one. The best place to buy is amazon (because of reviews and price). take a look Lexmark Printhead cheers
Lexmark Prospect Pro 205 printhead error
Sounds like you need new printhead. Take a look on amazon for replacement, here: Genuine Lexmark 100xl 100 Print Head 14N0700 14N1339 Printhead for Lexmark.... I hope this was helpful, Cheers
Jan 07, 2011 | Lexmark Office Equipment & Supplies
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
931.01 Printhead Service Error
there is a Printhead error - No first sync
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark X544n All-In-One Laser Printer Logo
2,567 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
