RCA 25110RE3 Phone Logo
Question about RCA 25110RE3 Phone
My RCA Cordless handset model H5401 shows an error message of: "IMPOSSIBLE" when I try to dial out. it happened all of a sudden and I cannot locate how to fix this problem within the user manual. HELP. thank you
Posted by smilesofcaro on
1 Related Answer
Anonymous
  • 567 Answers
SOURCE: Hi I need some belt
This component has been discontinued and is hard to find now.
I researched a bit and managed to locate it though.
The RCA Removable Belt Clip (SKU#PC009) can be purchased here.
Please visit:
http://www.matelectronics.com/acatalog/Mat_Electronics_RCA_Parts_Explosion_Sale____469.html
Search for Reference #52774.
You will be able to purchase it from there.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 22, 2010
How do I check L1 message waiting
I had the same issue on my RCA 25255re2 and worked with customer service at RCA. They had me hold down the delete button for 5 seconds, release the delete button, then press delete one more time. That cleared the phantom L1 message waiting issue we were having at my office
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
I have a cs6328-3 model vtech digital ans system. It is only 1month since purchase. the three handsets are the original handsets and i have no additional handsets that were added. Error: out of range / no...
Periodically, while using my Vtech Model CS6328-3 phone, it becomes virtually impossible to hear the other party - interestingly, it affects other non-cordless phones in the home at the same time. Just like that, the volume may come back. The person on the other end sometimes has the same proble hearing me - but not always. Have switched back to a previous Panasonic phone system in the interim, no problems. Seems to be the Vtech system. Any thoughts?
I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
3helpful
2answers
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
2answers
Cdp24201 base handset wont work
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
1helpful
Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Top RCA Lands Phones Experts
Marvin
Marvin
Tom Chichester
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
