Question about Palm Z22 Handheld
Battery died. Charged Palm Z22 (many times), let it drain (many times), performed hard, soft and warm resets. Palm will not turn off using power button. The resets show the first Palm screen but never the Palm Powered screen. It just changes to a grey, blank screen (stays lit but blank). When I try the UP button + reset, I get a 4-color block screen and then "S3C2418A Downloader Connecting USB..." screen, but nothing happens whether it's connected to PC or not. The screen is obviously ok, or I wouldn't be getting the first Palm screen or the USB screen. What do you suggest?
Posted by scraphapp741 on
  • robin-dusty graves Jan 28, 2019
    What you describe fits the description perfectly of an almost dead Z22 battery. I deliberately ran down a number of batteries to see what happens on a Z22 BOOT SEQUENCE. If the battery does not show high enough voltage during BOOT, the Z22 will shut down. However, if the battery dies or shorts out during "shutdown", the shutdown sequence will not work properly. If you connect a +5 Volt USB source - during "shutdown", the Z22 can "hang" and give strange screens. This fits perfectly. If you open the Z22 and remove the dead/shorting Lithium battery, and quickly wire in 3 AA batteries, you can quickly boot properly and TEST that the Z22 works properly. In fact, once the Z22 does boot, you can remove the batteries, and it will happily keep working on the +5 Volt USB source, since the Z22 "thinks" the battery is working just fine. You see the entire Step-By-Step process at: http://kidbots.com/WEBADD/Z22_PALM_PILOT...
    I am surprised that fixya.com did not pop-up with my previous 32 ANSWERS for Z22 Questions. The inane "answer" to Replace It, is funny, and not an answer at all!
    Good Luck
    robin dusty graves
Marvin
    Top Expert:
  • Palm Master
  • 85,239 Answers
Replace it.
Posted on Apr 17, 2017
5 Related Answers
Anonymous
SOURCE: Palm Z22
Just had to do a hard reset myself and it's not straight forward! While holding down the power button, BRIEFLY press the reset button on the back of the palm. DO NOT RELEASE the POWER button until you see the GRAY screen with the Palm logo (not the first screen with the palm logo). That should start the hard reset for you.
Posted on Aug 23, 2007
Anonymous
SOURCE: Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
Posted on Aug 06, 2008
Anonymous
SOURCE: palm z22 usb cable connection problem
Hello Every body,
I had the same problem, and went to the device manager. It said the driver was gone. So to solve this, Just uninstall, and reinstall the software. And it will Sync. at least it did for me.
Hope this helps,
Dakotah
Posted on Aug 13, 2008
Anonymous
  • 45 Answers
SOURCE: PALM Z22
Your problem might be a simple one. Hopefully so:
Run a business card around the edges of the screen between the screen and the plastic housing to see if there is any trapped dirt or other debri. If there is, it will hold down that point of the screen and prevent any further input. Be sure to remove anything you find.
Also, sometimes the screen protectors themselves will shift just enough to cause the same issue. Be sure it is not wedged tightly between the screen and case.
I hope this is it and helps!
Posted on Aug 29, 2008
Anonymous
  • 66 Answers
SOURCE: how to do a hard reset on a palm z22?
Hi here are the steps but ensure to backup data before you make a hard reset
Press and hold the power button
While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
Wait for the Palm Powered™logo to appear, and then release the power button.
When you see the message that warns you about erasing all of the info on your handheld, do one of the following:• Press Up on the 5-way navigator to finish the reset and show the touchscreen.• Press any other button to do a soft reset.
When prompted, tap to align the screen, and then select the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar.
When the Welcome screenappears, the hard reset iscomplete
Hope this helps and do let me know
Posted on Mar 07, 2009
Palm z22 touch screen not responding touchscreen
The Z22 palm PDA is subjected to 3 points of failure. I got a used Z22 and discovered all 3 over the course of a few years. The touchscreen digitizer on the front is a plastic sheet on the top, and a glass screen on the bottom. Invisible layers of conductive paint are facing each other. Simply carrying the Z22 in your pocket, purse, briefcase, or even storing it in a drawer with pencils, staplers, rulers, etc., will, over time, deform the screen, and the damage is cumulative, so that the screen gets worse and worse. It is imperative to have a solid sheet of plastic or hard material over the screen at all times that you are not using it. Leaving the Z22 in direct hot sunlight will heat up and soften the screen, making the problem worse. Carrying the Z22 screen in your pocket on a hot day when you are sweating, will do the same. People report that the Z22 will work in a cool place like North New York, but the screen will quit, when they travel to Florida (hot). I have temporarily fixed the touchscreen by putting it in a ziplock, and sticking it in the freezer to shrink the top layer of plastic. That only worked twice. Then I use a hair dryer to heat the screen VERY hot, to shrink the screen - which worked very well, until I put it in a soft zippered camera case, which gently pushed the screen. Then I took the screen apart completely ( which no one has ever reported doing) and this worked amazingly well, -again- until I put it in a soft case that pushed the screen against the glass backing. I eventually replaced the touchscreen ($10 free shipping from China). All the information is on my tiny website at
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of Death, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
All these problems are discussed and solutions posted, with photos on my website. Also are discussions on what to do with the Z22, where to get parts, how to maintain the Z22, and how to get data off the device onto the new 64 bit WINDOWS computers...
Good luck. The Z22 was an amazing device in its day, and people report that there were a few software programs for it that have never been made since - hence, they still use it...
robindustygraves Sept 2014
Z22 PALM PILOT a75f3784-08d5-4a1b-85ae-67e479181e27.jpg b2146887-a4b6-43a4-931b-b0f3438348ac.jpg 12202c43-26c3-47df-a31f-bc94507b7482.jpg fc737f81-6cb4-492d-b006-199c695a4776.jpg
Aug 02, 2013 | Palm Z22 Handheld
Palm z22 touchscreen not responding
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of *****, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
( I am posting this answer on a few places on fixya, so that people with Z22's can find it easily ! )
Z22 PALM PILOT
0622ac5f-1a8b-4e47-b2d3-41600350d21e.jpg Z22 PALM PILOT d66589a5-9eed-4439-8a3e-5cc1944e2ab2.jpg 61ca79eb-5d24-47a7-9aea-aab6200c19b8.jpg c90ee8fa-0ef6-4f86-8024-0ebb9f0cb5c1.jpg
Aug 08, 2011 | Palm Z22 Handheld
I have a Palm z22 that won't keep a charge. My
The Palm Z22 is, I have found out, a bullet-proof design in regards to reliably keeping your valuable "DATA" safe over time. The Engineers at PALM really did a good job of Data integrity compared to many other devices. HOWEVER -- there are 3 common problems with the growing AGE of the Z22, 2 are with the dying batteries, and 1 with the years of wear and tear on the touch screen. The battery is a typical square, thin, modern Lithium battery, wired in with two wires ( + positive, red, and - negative, black ) that can be
taken out and replaced if you take the unit apart. In a brand new, in-the-box package, the battery is dying simply from old age. If the Z22 was used heavily, the constant cycling from dead to fully charged wears out the battery even more. The Touchscreen is a thin layer of plastic stretched over a sheet of glass, with a tiny air gap in between. Over time, the top plastic layer deforms - with hot and cold, air pressure changes, and being pressed by wearing the unit in a pocket, purse, briefcase, or even in a drawer with pencils, pens, and staplers etc. It is very important to have a hard cover over the screen! Other than just having the battery loose its weak charge continually, there is a problem with the unit getting into a state of BLACK SCREEN - it does not charge and remains "apparently" dead, since the logic circuits are in an invalid state, and it can only be reset if the battery dies COMPLETELY to remove the power on the logic circuits.
I have covered the topics of the battery problems, the data problems, the screen problems, and the disassembly, maintenance, and security, and how to get data off the unit, particularly to the new Windows Operating Systems that were developed AFTER the Z22 was no longer made. This is at
I have ripped apart the Z22 repeatedly, and posted pictures of the various steps to service these units. There are links to aftermarket software to transfer data, and examples of how to USE the Z22, for valid purposes. This should be a one-stop source for any information or troublehooting the Z22, for those who have the Z22 and want to keep it operating!
good luck
robin dusty graves
Z22 PALM PILOT
palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-0.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-1.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-3.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-6.jpg palm-z22-keep-charge#solution-section-jquljdhkw5zrsfvn5uli2qb2-3-10.jpg
Mar 09, 2010 | Palm Z22 Handheld
My Palm Z22 won't turn on. If I do a hard reset
It absolutely won't, you don't have to worry. I've done it several times, and I know I was really nervous at first, but it's fine.
Nov 01, 2009 | Palm Z22 Handheld
Palm z22 freezes up when traveling by air. hard
You need to make sure that you have all your information backed up on your computer as a hard reset will erase everything on your hand held. Here are the steps to do a hard reset:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your handheld do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your handheld to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Aug 26, 2009 | Palm Z22 Handheld
Time change killed palm
If thatn doesn't work, put your palm aside for a week allowing battery to completely drain. Repeat procedure after a full charge. If this is helpful please post as such.
Mar 08, 2009 | Palm Z22 Handheld
Screen goes blank and requires a soft reset with "memo"
I believe that this problem relates to the BlackScreenOFDeath or BSoD - which is caused by a low or weak battery allowing the CONTROL Logic circuits to get into an invalid state where the ON/OFF/SLEEP/CHARGE/ FUNCTION transistors are niether on nor off. I would recommend getting a new battery as soon as possible. Doing a SOFT RESET "may" get you temporarily going again. DO NOT do a HARD RESET !. I have posted many discussions on the Z22 that you may find helpful, on my tiny website,
One other possibility, is to take apart the Z22, and wipe the buttons and traces with a soft damp cloth to remove oils, water, and possible spilt liquids from the touch/snap/button/discs areas. Even the tiniest trace of conductive liquids will short out the logic circuits, causing "unknown: states on the control circuits.
My answer on the BLack ScreenofDeath, is as follows:
__________________________________________________
The Z22 suffers from 3 problems. One of these is the Black Screen of *****. I got a used Z22, and over the years discovered this problem. The small battery was a perfect fit of power and size when manufactured, decades ago, but, time alone has deteriorated the capacity, so that a "NEW" , sealed-in-the-box Z22 today, has a weak, dying battery that needs replacing. These are $10 free shipping from China. The BSoD seems to be caused by a dip in power from the battery to the LOGIC CIRCUITS that control the ON/OFF/SLEEP/CHARGE, etc states of the Z22. If the logic gets out of sync, the unit is in an INVALID state, will not charge, nor respond to the LOGIC buttons on the front - these buttons are NOT the standard ON/OFF buttons from the past that mechanically connected or diss-connected power. All the buttons on the Z22 are touch snap disks that are connected to transistors, to flip logic states. THUS, is the power in any of the transistors gets low, the transistor is neither ON nor OFF, and the control circuits are in a messed-up state. Or another way of looking at it, the ON button is a logic gate on a transistor network, and the only way to activate the "ON" logic state, is with full power to the circuits! -- the power on the Z22 is ALWAYS ON. . . The screen may turn off, and the chips may go into "sleep" mode, but the Z22 is always on. SO if there as a weak battery, you may get the random Black Screen of *****. The GOOD news, is the the DATA and programs that you purchased are incredibly SAFE, as long as you do NOT do the HARD RESET (which someone suggested ! (NOT ) ). I have ripped apart the Z22 dozens of times, and subjected it to freezing and heating and all sorts of horrible things, the data has always been 100% reliable, -- stored in permanent memory. There is a quick way to get rid of the BSoD - you have to open the unit and cut one of the two battery wires, wait 2 minutes to kill the logic circuit power, then re-connect. I added a switch on the Z22, just for this purpose. I would recommend, if you get the Z22 re-powered, to get a new battery as soon as possible. This should clear the BSoD for a while. See my tiny website :
There are many photographs and step by step procedures to try to get the data off the device, maintain the Z22, get parts, and use the Z22 with the new 64 Bit Windows computers. The BEST way to use the Z22 would be to get an old Widows 32 bit laptop (ie WinXP), and simply connect the Z22 in a standard way using the software that it was designed for... The new patches to 64 bit machines, are very limited, and many previous features do not work.
So the bottom line - all your data, information, and programs are safe. You simply have to reset the LOGIC CIRCUITS (this has nothing to do with the PALM Z22 SOFT and HARD Resets !) - it has to do with disconnecting the power from the battery, or waiting until the battery is COMPLETELY DEAD ! (which can take a long time! )...
Good luck
robindustygraves sept 2014 ( robin dusty graves )
Z22 PALM PILOT
Z22 PALM PILOT b24a4c23-cde3-44eb-a542-221e23771cfb.jpg 5d677a3f-163a-4546-ae79-d98c6fb397b6.jpg 5cb49c67-a9f7-4dbc-90df-4cf481cf4e2d.jpg badc8899-3493-408c-b9aa-fa81dc391d93.jpg ab336a44-9ab4-44a2-97f6-d3720b8639c9.jpg
Jan 30, 2009 | Palm Z22 Handheld
Palm Z22 will not turn on
I had this problem in the very beginning and a few times after. What worked is the following.
Put it to charge for at least half an hour. You won't see it is charging or anything.
Then, while connected to the charger, press the reset button.
Have you guys tried it like this already?
Feb 02, 2008 | Palm Z22 Handheld
c boekema
Jan 14, 2008 | Palm Z22 Handheld
Palm Z22 Handheld Logo
277 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
