Question about Palm AT&T C/PHONE PALM CENTRO S64801
Hi, im trying to save all my contacts from phone to sim card. I have a palm pre. can u help please?
Posted by maiya_andra on
Kazim ERGUNEY
  • 577 Answers
Hi,yes and no !! Sim cards is capable either 100 or 250 contacts capability....depending on the kind of Sim provided by your company..if your contacts is within this figures yes ..otherwise no..
when your contacts are open go to upper menu and you will see the option of function..if you click it it will copy to Sim...
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me
to continue f
or Helping out the Community :)
Thanks
Posted on Aug 16, 2011
barmatours
    New Friend:
How do I copy my contact from sim
Card to my phone book X10I
Posted on Aug 31, 2011
How to unlock Palm pre
To Unlock the Palm-One Pre from the Network lock,Use the Unlock code,that is best to Unlock the Phone...You can get the Unlock code from here Ttheunlockspot.com and Unlock it.You can follow the instructions below and Unlock it step by step:
Palm One Pre Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Palm One Pre mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Pre mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Palm One Pre with a Not ACCEPTED SIM Card.
2. Your Palm One Pre will ask for an unlock code.
3. Enter the Unlock Code we sent you.
4. Your Palm One Pre is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Palm One Pre is locked to.
Aug 14, 2011 | Palm Pre Cell Phone
I have a brand new palm pre from sprint I really don't know much about phones but this one doesn't have a SIM Card...I'm living in germany i prepaid phone now..but i want to use my asome palm...
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider. To get the security code/restriction code to unlock the cellphone from the current cell phone provider so you can use the SIM card with adifferent phone provider, Please click on this link and follow my instructions:- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEBsites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ Try this WEB sites - http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ http://www.unlock-free.com http://www.unlock-zone.com/ http://www.unlocking.com/
Jul 17, 2011 | Cell Phones
Can i unlock a sprint palm pre to be used on an at&t service plan
absolutely not. SPrint is a CDMA network, meaning the device must be manufactured specifically for that network. CDMA networks use HEXidecimal codes to connect to the network. This is the same type of service used by cricket, verizon, and many other providers that use CDMA devices. Your Palm can be "flashed" with the proper setting to work on any of these networks, but as long as the network requires a sim card it will not. Sim cards are used on GSM networks, which run on a totally different frequency lvl.
THe only way to make the device work is to be a phone genius and "hack" a sim port onto the board. Unfortunately, this is so complicated, i have only been able to it to one device (a first generation palm centro) and the device experienced many problems and after a few months, shorted out completely.
SO DONT TRY!!!! your best bet is to find someone that will trade you straigh out.
GOOD LUCK AND PLS RATE THIS POST!!!!!
Jun 07, 2010 | Palm Pre Cell Phone
I MADE THE MISTAKE OF FOGETTING MY PIN TO GET INTO PALM PRE..HOW CAN I UNLOCK IT?
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Mar 15, 2010 | Palm Pre Cell Phone
Hi my samsung D 900 soul drop and its not working im
It all depends on what type of phone you have, and I don't mean which brand. If you phones is a GSM technology phone the it requires a SIM card to work, all of your contacts should be already saved in your SIM card. The same goes for the messages. All of this is possible only if you had save all your contacts and messages in your SIM card, but if you saved your contacts and your messages in your phone, and your phone don't power on, then you lost it. Try the SIM card in another phone that uses the very same band as your old phone, and check in the phonebook, if it shows empty, then all your contacts were saved in the phone.
Oct 11, 2009 | Cell Phones
Sim chip
you should be able to go to your contact list and under options it ask if you want to copy to sim. do that and then in contacts under options you should see where it says phone,sim card , phone and sim card. that chooses where to save them when you add a new number. hope this helps rate please
Aug 14, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Vodaphone Palm Treo 650 and when I put my CHIP into
Hi, not really familiar with Plm devices but insert your sim in to the palm go to contacts and look for Copy to sim or something similar. Sim cards have limited memory,varying from 100 to 250 contacts and 30 to 50 sms.Last would be one by one.
Apr 23, 2009 | Cell Phones
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
98 people viewed this question
Top Palm Cell Phones Experts
Marvin
Marvin
Jax Planet
Jax Planet
Muntejaya Ginting
Muntejaya Ginting
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
