YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
SOURCE: help retun 4000 to default
Press menu and dial 8-9-3-7-6-2-0-0 to reset pin to 0000. If found this on another forum and it works - just tried it. Cheers.
SOURCE: Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
SOURCE: Gigaset 8800 PIN reset
Note: When you turn the handset back on, the handset PIN will be reset to 0000.
SOURCE: siemens gigaset 2420. how do i reset pin on desktop base
Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
