Question about Samsung Computers & Internet
My samsung tv screen just blacked out. how do i find a reset button
Posted by rsanders316 on
Norisil Cabasag
    Novelist:
  • 139 Answers
Samsung is known for producing high-quality LCD televisions with excellent imaging and sound. Unfortunately, LCD televisions, like all electronics, are subject to problems on occasion. Common Samsung LCD problems include a television with sound but no picture, sometimes due to a faulty power supply. Although these problems can be difficult to fix by yourself, it is sometimes possible to extend your television's warranty by contacting Samsung.
  1. Diagnosing and Fixing A TV With No Picture
    • Problems can often occur with even relatively new Samsung LCD TVs. Some customers report their screen going black shortly after turning on the television, even though the TV's speakers continue to produce sound. You can test and rule out a number of things before concluding that your TV has a hardware defect.
      First, check the input settings of your television. Often, users will experience a dark screen when first turning on their television if the selected input corresponds with a turned-off or unplugged input, such as a gaming system or DVD player. If the problem persists, try reconnecting all cables on the back or sides of the television. It's possible that one of your cables has gone dead. If you have access to other cables, try swapping these in and see if the problem persists. Some customers report that turning the television off and unplugging it for an extended period of time, up to 24 hours, can fix the black-screen issue.
    Power Supply Issues
    • If you've tried all of these suggestions and problems persist, it's possible that the power supply inside the television is defective or broken. The power supply for most Samsung LCD televisions will cost around $150, with labor costs of around $250. Unless you have a fair amount of TV repair expertise, this is probably not the sort of repair you'd want to attempt yourself. Also be aware that occasionally, especially with older television models, the part you need might be out of stock. Getting a back-ordered part shipped to you or your local repair shop could take up to a month.
    Warranty Information
    • If you register your Samsung LCD TV online, your standard one-year warranty may be subject to a three-month extension. Be sure to save your bill of sale; Samsung might ask you to send them a faxed copy of it when you ask for your warranty extension. If your television is still within its warranty period, it's probably best to contact Samsung and ask for a replacement television, or a professional repair service. Problems that fix themselves may crop up and become permanent over time, and you don't want to be stuck with a costly repair outside of your warranty period.
I hope you find it very helpful. Best regards.
Posted on Aug 16, 2011
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
How to unlock screen, when code number is lost?
Reset LG G2x P999 to Restore Factory Default Settings
How to hard reset (factory reset) the LG G2x P999?
There are two different ways you can reset your LG G2x P999 to its factory default settings, via settings menu and using phone buttons. WARNING!!! If a factory reset (hard reset) is performed, all installed application and user data such as messages, phone contacts, image, video and audio files will be erased. Please remember to back up any important data before performing a factory reset.
Reset LG G2x P999 using Settings Menu
  1. From the Home screen, press the Menu Key .
  2. Touch Settings > Privacy > Factory data reset.
  3. Read the warning and touch Reset phone.
  4. Touch Erase everything.
Reset LG G2x P999 using Phone Buttons
  1. Turn the power off.
  2. Press and hold the following keys at the same time for 15 seconds: Home Key+ Power Key + Down Volume Key.
  3. When the LG logo is displayed, release the keys. The phone will turn on and
    perform a factory reset immediately.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card.
Mar 26, 2015 | LG G2x / Optimus 2X 4G Android T-Mobi8GB...
How to factory reset with only remote, while screen remains black w/ 5 thin horizontal colored lines streaking. Why is screen black?
Without a proper screen, you can't do a factory reset to this set. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 07, 2014 | Samsung PN42B450 Plasma TV
Samsung TV , black screen
Check for the timer settings if possible reset to default......
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung projection 42 in. floor model, powers on
tv is in shutdown, drawing to much current. usually focus or high voltage divider (sometimes they are one). not usually the power supply.
Jul 05, 2009 | Samsung Televison & Video
Could you tell me pls where the factory reset button is ?
its on the side of tv! but 1st take on the black lable on the back than push that button in than the red green and blue will can on ones done put black lable back on and thats than good luck
Dec 30, 2008 | Samsung SP42P2S Television
Black bar down screen left side 12 inches in from left
this is either a circuit board problem or the panel could have a bad tab
Dec 07, 2007 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Computers & Internet Logo
233 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
