Question about Samsung Cameras
I have a samsung Digimax 360 camera and it usually connects to a computer with a windows 7 system. In the last week or two I cannot get content from the camera into the computer. I have had the siuation cheked for computer problems by the proramme experts and they conclude that the problem is likely to be the camera. How can I check that the fault is the camera and how could this be rectified. Thanks, CJKnights
Posted by cjknights6 on
Tony Parsons
  • Samsung Master
  • 6,301 Answers
Why not just use a USB card reader ?
Posted on Jul 24, 2017
5 Related Answers
Anonymous
  • 542 Answers
SOURCE: Can my Samsung Digimax A6 be used as a webcam?
No. For a camera to be used as a webcam, it requires special drivers and also the camera has to have webcam capabilities. The A6 has neither of those.
Posted on Sep 08, 2005
Anonymous
  • 2985 Answers
SOURCE: IXUS 700 zoom problem
contact customer support If has been dropped a repair price maybe well on the way to replacing the camera
Posted on Aug 01, 2007
SpotBert
Suzanne
  • 231 Answers
SOURCE: need drivers for digimax 4010
This appears to be the drivers for windows vista =>
http://originaldrivers.bee.pl/windows-driver-vista9.html
Posted on Dec 30, 2008
Anonymous
  • 146 Answers
SOURCE: can't get pics/video from my camera onto new computer
There are 2 ways of doing this.
1) You can use the provided drivers/software that comes with your camera - usually ont he bundled CD-ROM, follow instructions and install it - and you can plug your camera using USB and transfering straight from your camera....
OR (this is my prefered method)
2) buying one of those multicard readers (assuming your PC does not have built-in ones already).
If you are using a card reader you do not need to isntall anything - it will be recognized automatically under Windows XP or higher.
The flash memory card will be recognized like removable storage and displayed along with your hard drives - go to your control panel and you see it pop-up once your memory card is inserted into the slot, a new drive letter will appear under removable storage - you will access your files the same way as a hard drive, by double clicking on the respective icon (example: you have 1 hard drive (1 partition) and 1 DVD-ROM, in your case you would see letters A floppy, C (your hard drive) and D your DVD-ROM, and when you plug your memory card, E. (this is an example). Once you double click on the respective drive letter of your memory card you will see folder with files in them - there will usually be ONE folder which contains all the JPG and AVI or MPG files.
Posted on Aug 18, 2009
  • 102366 Answers
SOURCE: using windows 7. Camera not
Have you considered NOT connecting the camera to the computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Posted on Dec 06, 2010
Driver for windows 7
It is not your computer that needs drivers, it is the hardware you need to connect to the operating system that needs a driver. From Windows 7 and up, Microsoft only allows drivers, if the manufacturer asked for certification and the hardware and driver work conform Microsofts demands. If the hardware and driver is certified the driver is also on the Microsoft website. Most of the time if you use new hardware the operating system goes to Microsoft to see if there is a correct driver and then installs the driver.
For your camera, just install the Samsung software that came with the camera. And if you can't find the CD, download the software form the Samsung website, under support.
Sep 25, 2014 | Samsung Digimax D73 Digital Camera
Software for my samsung digimax d53 camera is incompatable with windows 7
You don't need the Samsung software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 29, 2012 | Samsung Digimax D53 Digital Camera
Why cant i use my digimax now with windows 7
Your camera doesn't care what operating system you have on your computer. Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Mar 06, 2012 | Samsung Digimax S500 Digital Camera
I have a samsung digimax s500 camera that I trying to download pictures from to a windows 7 OS. Is there an updated Digimax program that I can download?
you can get drivers from here:
http://www.samsung.com/us/support/owners/product/DIGIMAX%20S500
although if you're running windows 7, you should be able to goto the Computer icon, and it should display removable device drive (which should be your camera) And you should be able to copy the pictures from there to the hard drive
Mar 07, 2011 | Samsung Digimax S500 Digital Camera
Samsung camera digamax x600 cyber 360. plug into computer via usb. have connecting computer message on camera screen. does not connect. running windows 7. go to devices and printers and there is...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 27, 2011 | Samsung Digimax S600 / Kenox S600 / Cyber...
How to download pictures for Samsung Digimax S500 for Windows 7
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 14, 2011 | Samsung Digimax S500 Digital Camera
Hello there,........i have a samsung digimax s500cyber530 that i bought appox: 4 years ago?,.....and we just several days ago replaced an 8 year old gateway "windows" computer w/a brand new HP...
Once you get the camera working again by the "shuffling technique", don't connect it to the computer again. Instead, purchase an inexpensive card reader and use it to download pictures from now on. typrice_31.jpg
Nov 17, 2010 | Samsung Digimax 530 Digital Camera
I have an older Samsung Digimax 301 digital camera and I recently got updated to Windows 7. My camera's software isn't compatible anymore - is there a download that I can use to update my software so I...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Nov 10, 2010 | Samsung Digimax 301 Digital Camera
Power supply
You can download the manual from the link below: http://downloadcenter.samsung.com/content/UM/200703/20070330162556328_DigimaxS500_S600_ENG.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Samsung Digimax S630 Digital Camera
Connecting the digimax to my computer
You didn't state where this yellow exclamation mark was located. I assume that it is located next to "Universal Serial Bus controllers". If you cleaned off the hard disk and started from scratch, there are several motherboard drivers that must be installed. These are usually on a disk that comes with the computer (or motherboard). One of those drivers is usually something about USB.
Sep 08, 2005 | Samsung Digimax 360 Digital Camera
Cameras Logo
78 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
