My dell laptop doesnot work proberly if we power on a dell laptop. adopter let should be off then remove from the lap power will be on. whats the problem
Posted by bala_mnsk on
Chris Hingee
  • Computers & ... Master
  • 32,281 Answers
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Aug 16, 2011
Dell inspiron n15010
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
Jan 13, 2014 | Dell Computers & Internet
Dell vostro 1000 power button press on..but lap is not working
unplug the power chord, take the battery out for 30 seconds. plug them both back in, restart.
Let me know.
tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 09, 2013 | Dell Vostro 1000 Notebook
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
D610 Dell Laptop
it seems to be a problem with motherboard as you said you have replaced power supply and ac adaptor , try disconnecting external pheripherals do a flea power it doesnot start then you will have to replace motherboard
Jan 09, 2010 | Dell (F2273) Motherboard
My dog chewed through the power cord on my dell D600 lap top and killed it, i bought a new power supply but it still wont start up, thinking that it may have shorted some thing out i put in a new power...
Verify that the light on the power block is green with the cable only connected to the wall. If the light goes out when it's connected to the PC the your motherboard is bad.
Nov 22, 2009 | Dell Latitude D600 Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Laptop battery terminal problem
check the power setting in control panel > power options, running from battery may be disabled
Jun 08, 2009 | Matsonic MS9337c Motherboard
Presario V2000 - Does not turn on..
Hi
Have you tested your Power Adopter, it is working if yes check the battery, This may be the problem
Boopathy
Aug 10, 2008 | HP Compaq Presario V2000 Notebook
DELL LAPTOP PP19L - INPUT POWER FROM ADOPTER SHORT CIRCUITED - TO BE FOUND OUT
sounds like the charging circuitry is faulty. I was looking at the service manual and it looks like it is on the motherboard.
Here is the online manual, see what you think.
http://support.dell.com/support/edocs/systems/ins630/en/sm/index.htm
Dec 02, 2007 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
80 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
