Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Hi. There is a continual ice build up in my bottom crisper drawers and on the bottom shelf. What do I need to do? Thanks.
Posted by amaretto_597 on
Leo Ponder
    President:
  • 3,773 Answers
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it.
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
I need a glass shelf for the crisper drawers 22 5/8
The glass shelf is no longer available but having someone cut glass to size will work, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Puddles on top shelf and under crisper drawers
This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
May 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Oct 16, 2008 | Sub-Zero Refrigerators
Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Aug 23, 2008 | Maytag MSD2656G Side by Side Refrigerator
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
141 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
