Question about Wells F14 Deep Fryer
IS THEIR A PHONE NUMBER THAT I CAN TALK TO SOMEONE. MY WELLS DEEP FRYER WANT GET HOT UNLESS I TAKE THE BACK OFF AND MOVE A SMALL SWITCH UP AND DOWN.I WOULD LIKE TO GET THAT PART. DO YOU HAVE ANYONE IN THE DALLAS AREA. THANK YOU
Posted by aanderson002 on
Angel Joseph Jr.
  • Wells Expert
  • 684 Answers
Hi there.
You can call 214-343-2548 for Wells at Texas.
Regards.
Posted on Aug 17, 2011
Who should I talk to about putting on a secondary high limit control switch on a Wells F88 model deep fryer. Did not pass inspection with our insurance.
Any competent service technician could cobble something like this together, but I'd challenge the insurance company, as this fryer is UL approved. Such a modification would be expensive and void the warranty and NSF and UL approveals.
Aug 19, 2014 | Wells Kitchen Appliances - Others
Deep fryer WIRING DIAGRAM
You can download wells fryer wiring diagram at www.wells-bloomfield.com for free.
Jan 19, 2014 | Wells F-67 21167 Deep Fryer
I have a Wells WVAE-55FS 240 55-lb Ventless Fryer, Basket Lift, Oil Filter, Solid State Controls, 240/3... and the check filter light went on.... how do i check my filter and where is my filter located?...
Hi there!
Your filter may need replacement, that is what the light prompts.
For complete owners manual of your unit, you may visit www.wellsbloomfield.com
Regards.
Sep 04, 2011 | Wells WVAE30F Deep Fryer
Need a wiring schematic for Wells F-85 Deep Fryer
You can download Wells F 85 Deep Fryer at http://www.wellsbloomfield.com
Regards.
Jun 10, 2011 | Wells F-85 Deep Fryer
HELP PLEase
Hello. Here is the link to your units manual, page 3, 7, and 13 tell most of the specs, page 13 has a part number, and specifications for the proper cord.
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20OpM/301(b)%20307588%20OpM%20CT%20Std%20Fryer.pdf
Lowes probably does not have that high an amperage plug first of all, find an electrical supply house, or have an electrician get it and install it for you. You may actually have a 3 phase unit, but it does not specify that unit as being set for 3 phase, older units from a certain restaurant were though. If you want to find the terminal block, remove the pot, and then remove the inside rear cover, once removed you should find the terminal block inside, your wiring for the cord should go here ( a wiring diagram ).
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307309.pdf
Hope this helped, and thank you.
If you need more help, ask me.
Apr 12, 2009 | Wells F-55(21154) Deep Fryer
Wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Mar 22, 2009 | Wells F-686 Deep Fryer
Wells f 49 fryer
Yes it should have resistance through it unless it has been opened by a rise in temperature. Tell me what your problem is I can probably help you out.
Thanks
Jul 15, 2008 | Wells F-49 21148 Deep Fryer
Please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Jul 08, 2008 | Wells LLF-14 Deep Fryer
Wiring diagram for wells f-67 deep fryer
OK what I have here is the link directly from wells on this fryer, this is the wiring schematic.
http://www.wellsbloomfield.com/WELLS%20TECH/Wiring%20Diagrams/pdf/307302.pdf
Hope this helps You
please rate me
Feb 09, 2008 | Wells F-67 21167 Deep Fryer
Frequent tripping of the hight limit switch
The high limit switch itself is getting weak , replace it and problem solved!
Sep 12, 2007 | Wells F-49 21148 Deep Fryer
Wells F14 Deep Fryer Logo
42 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
