Cobra 148 GTL 120-Channels Base CB Radio Logo
Posted on Aug 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO AUDIO / NO TX - Cobra 148 GTL 120-Channels Base CB Radio
Laron
Level 2:
Novelist:
  • Expert 146 Answers
  • Posted on Sep 10, 2011
 Laron
Expert
Level 2:
Novelist:
Answers
146
Questions
0
Helped
46028
Points
197
OK bare with me now i have no idea of your knowledge level with CB/ SSB radios.
Lets make sure our setting on radio face is correct before we decide this is an mechanical problem.
Set the following
  • Volume knob 12 o'clock
  • Dynamike knob 12 o'clock
  • Squelch full counter clockwise
  • Rf gain full clockwise
  • Select S/RF position on the SWR/CAL switch
  • Select AM position on the USB/AM/LSB switch
  • Select CB on the CB/PA switch
Now there will be some critics with opinions on the next instructions. Place a small screwdriver or test lead from a multimeter in center conductor of antenna jack listen for onair noise or radios operators to verify RX is working. Now remove the antenna/screwdrive/testlead. Then key mic just long enough to notice if the meter is swinging do not hold the mic button long this can damage the final. I tell you to do it this way rather that connected to your antenna system so we can eliminate the question if it is you antenna sytem or the radio.
If the LSB or USB was selected when you keyed the mic you would see no meter movement this is due to the lack of a deadkey or carrier for SSB which is a much more efficient method of transmitting on AM.
There are few things that affected the rx and tx together.
tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
tip
I hope that helps.
I have a tti cb radio but the wires have come away from the mic but i dont know what colours go to what number can you help
one should be a ground. look at the board were the wire is.. and its obvious that its a ground pin 1. then should have 3 remaining. one will be tx.. touch the others to ground to see which one makes it tx.. theres your pin 3 tx.. on a galaxy pin 4 is not used. thats rx pin4 cobra radios would have a increase in rx audio when this is connected to grnd. the last would be audio. once you find grnd and tx. reconnect mic and put to pin 2 audio. the last 2 wires that gives it audio..
I have an onkyo receiver tx-sr603x. I can get
audio amplifier´s damaged need to be replaced
tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
tip
I hope that helps.
I removed my Roger Beep from my Eagle Sidewinder 400, It still receives but will not transmit. What do I have to connect back up for it to start transmitting again? I'd be Thanking you for any help.....
If the radio is not going into TX, then you have not connected the TX line back up,
If there is no audio when you TX you have left the audio wire off.
The radio usually needs 4 wires.
TX (Puts radio into TX)
Audio (this carries the audio from the mic into the modulator)
Screen (ground cable (earth))
RX (not as common these days)
Can you tell me if my receiver is digital? The model is TX-SV525. My E-mail is [email protected]. Thank you.
your tx-sv525 audio video control tuner amp is has full analog connections therefore it is analog.
2answers
Onkyo TX-SV525 Receiver
Ve a http://audio.manualsonline.com,Suerte.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
