Trans fluid is measured by pints ! So if 2 pints are equal to quart , you only need 5 quarts if it has 3.7 6 cylinder . And 3 quarts for the 2.4 4cylinder ! You may have added 5 quarts too many .
Try to reseat your cartridges in the printer. Open the printer cover and remove your cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Try to print or make a copy again.
If that doesn't help, try to insert a different known working cartridge to determine if your other cartridges are faulty.
Make sure you remove the print head protective tape. Also try doing a head cleaning and cartridge alignment page. If it still does not print check the cartridge well, you will see a assortment of copper pint that contact the circuit tracing on the print head, with the printer off get some achohol and a Q-tip and clean the pins there may be ink residue on them.
It could be that the cartridge has become dry. you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
First, print a test page from the printer's menu and see if the black lines and text look okay on that. If there is no or poor black printing, you need to replace the black cartridges or try cleaning the cartridge's nozzle with rubbing alcohol. If that looks fine you need to check the printer's settings in its properties on the system lift of printers.
just change the cartridge the head comes along with the new cartridge in HP everythime u change cartridge the pint head is changed automatically as it is fitted on cartridge,
if u are having lines and streaks and noisy prints just change the cartridge with a new one branded HP from HP website u can buy supplies
