Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
A GAME REQUIRES MORE RAM THAN YOU CURRENTLY HAVE IN YOUR COMPUTER. THE MORE GRAPHICS USED BY A COMPUTER THE MORE RAM YOU NEED. YOU NEED TO UPGRADE. RAM IS CHEAP NOW.
If the operating system is Windows XP or 2000, then restart the computer, press F8 before the loading screen (after BIOS) and select Safe Mode. Then login to the administrator's account. Click 'Start', and then 'Run'. Type "control userpasswords2" without quotes and press enter. Find your account on the list, click reset password, enter a new password, shutdown and switch back on.
Thanks for using FixYa. The serial number is usually located on the top, left, right, or back panel of the computer. The serial number is printer on a black sticker with white lettering.
And if you are unable to locate the serial code anywhere then right click on My computer icon on desktop, then click on properties and from there you will be able to see the serial number from there.
Please do accept the solution if the issue is resolved or else revert for further assistance.
