SOURCE: streaks in towels/sheets
From experience, Bleach will stay in the machine and bleach load after load (esp with an enamel or poly drum). Normally have to run a HOT empty cycle to clean it out.
SOURCE: REMOVE FRONT PANEL - ZIPPER PARTS STUCK IN DRUM GUIDE.
I found the parts manual on line at GE Appliances.
The replacement parts for the top indicated pictured two clips holding the front of the dryer in place.
I tried a narrow screw driver on the clips and that released the top.
With the top off, removing the front panel required removing two screws, lifting the drum and pulling slightly on the front panel.
After removing the wires from the door switch, I was able to find the broken zipper, clean out the fan, remove excess lint and reassemble.
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
SOURCE: Final Spin Drum BANGS around--terribly frightening noise!
Check the spring that hold the drum in place. They are about 4-5 inches long on the top of the drum at about 2 and 10 o'clock. The springs suspend the drum and if broken the drum will bang around. About $40 to order springs online
Also check on the bottom at about 4 and and 7 o'clock because there are 2 shock absorbers that help keep the drum from just bouncing and bouncing with no end in sight. Again about $40 to change each one.
I am in the process of the first repair and doesn't seem too difficult. The second was done about 6 months ago and was not too difficult but was awkward because you had to lay on the floor to get the replacement pins in place.
SOURCE: Washing machine noisey when drum turning
Try these out:
please rate my suggestion...
