SOURCE: Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Kenmore Microwave 62622 display says "locked" and will not operate
hold your finger on the locked button till the light goes out
SOURCE: Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
SOURCE: We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
SOURCE: How do I turn off Kenmore Microwave Beeping?
I've got a Honda Civic hybrid with the same noisy beeper. I can't have the parking lights on and the door open. I can't leave the key in the switch while making a phone call etc. I think we have to presume that like the Honda, there is no software controlled override on you microwave beeper... they know best and want you to feel safe and secure that no burglar will be able to make a cup-o-soup in your kitchen without waking you. A few screws and you should be able to expose the main circuit board and apply a layer of bubble gum or silicone caulk or JB Weld to the beeping device. Most have a small hole in a black plastic cylinder... so cover the hole and then test for loudness. For absolute silence, desolder the device from the circuit board and replace with a resistor matching the amount you measure across the beeper contacts with an ohm meter.
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
