SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
SOURCE: Black streaks when printing documents
you have to do maintance on the printer//needs to be cleaned/its in the printer program and then also clean rollers...;) oz
SOURCE: konica minolta pagepro 1400w paper jam
Did you extract the paper in one piece, as a whole? My best bet it that you have a small piece of paper trapped inside that gives you these problems.
SOURCE: konica minolta page pro 1400w printer driver
You have to use the latest versios of the driver, just to be sure. For Vista (32 bit) the latest version is v1.2.118.0 and for 64 bit the latest version is v1.3.301.2. If you don't have it, I can share it with you.
SOURCE: Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
