My remote will not work so i plug in my tv i hear clicking noises after 4 or 5 clicks it stops and the timer light is on and it stays on until i unlpug the tv......HELP
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
1) Turn photoeye away from lights. 2) Buy new timer since photoeye is first thing to malfunction on cheap Christmas timers. 3) Buy new timer at Lowes, and return defect in new package
Hi, TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front. Hope these info will help you. Thanks.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Th clicking is from the power relay. You will have to open it up, the first place to look will be the power supply module, look to see if it has any bad caps with leaking/bulging tops first, caps can look OK but can be bad due to high ESR.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you. Thanks.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
