Question about Jacuzzi Home
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin point the leak? Our tub is upstairs master bath & we just noticed stains on the downstairs ceiling directly below the tub. The access door only provides limited space to get tools into. We can see a water stain below the jets on the wood. Help!
Posted by pattiristagn on
US Parts Center
  • Jacuzzi Master
  • 719 Answers
If you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Posted on Aug 18, 2011
I have a jacuzzi whirlpool tub in my home that has started to leak at the three button control panel. Flooded out the bathroom so I cut a hole in the tile surround and when the pump is running it leak
First thing you need to do is remove some skirting so you can actually see where the water is coming from.
The 3 position control panel would only leak if the water was above it or covering it if it is located in the wall of the tub. That solution would only require the bather to NOT fill the tub quite so full.
IF however the water is coming from another location then that will be noticeable when you are checking for the water leak.
Dec 07, 2014 | Jacuzzi Home
Can I paint the wallboard that is in my bathroom?it is very smooth, but old. I plan to replace it around the tub with ceramic tile.
I think you can paint the old wallboard but you should get some advice from an experienced one before doing wallboard painting. You can also have a look at shower enclosures where you can find various bathroom accessories that will make your bathroom more elegant and attractive.
Mar 30, 2013 | Home
Should i use the same drywall in the bathroom as in the rest of the house?
I recommend using MR (Moisture Resistant) drywall for the bathroom, and possibly for the basement if there are moisture issues. It is not much more expensive, and it can save you a big headache later
Jan 16, 2013 | Drywall
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
In my bath the shower and/or tap on/off and temperature control unit is fitted independently on the wall. The plastic plaque covering the plumbing connection has progressively become cracked in three...
You will probably find, that the unit is 'Obselete'
And replacement parts, are not being produced anymore.
Why not change the broken piece, & do some fancy tiling around it.
I recently tiled around a circular mirror in bathroom, and actually it almost looks like a window.
As long as your 'finishing' is up to scratch.
Good luck with that, & don't forget to rate:)
Jul 28, 2009 | Home
Moen shower faucet problem
I need to ask a few questions to solve your problem.
What Model Shower body is it?
How big is the white plastic piece?
If it is about 6 inches around (just smaller than the face plate) and you are installing this shower body in a preexisting tub/shower, this piece can be discarded. It is a guide that is used so the tile contractor knows how much room is needed to service the valve once it is installed.
If this is not the case, just post with a few details and I'll modify my response.
Nov 20, 2008 | Moen Home
Home Logo
316 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
