Question about JVC Everio GZ-HD7 Camcorder
Good day, I own a JVC Hard Disk Camcoder Model No. GZ-HD7E, S/N. 12253242 and a PC, on which the JVC Digical Photo Navigator is installed. My problem is, that I have so far not been able to Backup my video files on my computer. I can display the photos and Videos on my computer, but cannot backup my videofiles on any of my PC Hard Drives. Any help will be much apreciated. One more question: Is the CU-VD40U Share Station Burner compatible with my Camcoder? Thanks in advance Rolf
Posted by rolf_frieden on
5 Related Answers
Anonymous
SOURCE: How to transfer videos on JVC Everio GZ-MG21U camcorder to DVD
YES!!! I GOT IT!!! Ok so the comp doesn't recognize the damn camera. I went around the problem!!! OOO so excited!!! Ok sooo simple, you'll slap yourself! Ok. First plug in your USB cord to the comp and you'll see the options play on pc, pc connection, etc. Select CREATE DVD! (You won't be able to see or select any of the files you are going to import, oh well.) You should see the regular screen pop up that says import, create, view pictures. Click IMPORT PICTURES. It will automatically import both pictures and video. For file name write something you can easily locate, ex: AAAAAAAAAAAAAA (you can change it later) Then open MOVIE MAKER. Click on IMPORT on the upper left hand corner and you'll see their demo video listed. Click on picture and video files on the bottom right hand corner and select ALL FILES. You should see what was downloaded!!! YAY!! I haven't burn a DVD yet but the files are there and the program should do it from there!
Posted on Sep 06, 2008
Anonymous
  • 152 Answers
SOURCE: can't burn from jvc everio hard disk cam to the share station
The Everio only accepts DVD-R discs, and the cheaper, the better. I burned a lot of coasters for my cats to chase when I tried using the 'name brand' discs. I buy cheap off-brand discs and have no problems.
Posted on Feb 03, 2009
Anonymous
  • 166 Answers
SOURCE: Can't copy video files from my onto my computer
hi there,
it seems u have not installed the software onto your computer. just install the software for your camcorder with the help of a CD that u might have recieved along with the it. then plug it through USB and its ready to transfer the videos.
good luck and do not forget to rate this solution.
thanks for using FixYa
Posted on Feb 11, 2009
Anonymous
  • 239 Answers
SOURCE: I need a manual for a JVC Everio Share Station
http://books.jvcservice.com/booklist.asp?Model=CU-VD10
here is the address to download your manual.
best of luck
please remember to rate me
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 03, 2009
Anonymous
  • 89 Answers
Hello to connect this device to your computer you need a standard USB cable. You can get this from any computer store for cheap.
You can download the manual from here:
http://resources.jvc.com/Resources/00/00/91/LYT1571-001A.pdf
Posted on May 27, 2009
I want User Manual for JVC GZ- HD7E
http://books.jvc.com/Download/510073276/LYT1734-001B.pdf
Feb 25, 2011 | JVC Everio GZ-HD7 Camcorder
Loud noise makes my camera go into failure and the video that has just been recorded deletes. It asks something about ''recover-yes or no'' How do I respond or exit without deleting?? When deleted can I...
Power off your camcorder, take the memory card or hard drive out of your cam, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
For Windows Version
For Mac version
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your files safely! Good luck!
Nov 01, 2009 | JVC Everio GZ-MG360 HDD Camcorder
How can I recover a file from a JVC Everio GZ-MG37U
First things first: DO NOT take any more videos or pictures with the camcorder(memory card) that you want to recover files from in case you may quite possibly ruin your chances.
Then take the memory card or hard drive out of your cam, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
For Windows Version
For Mac version
Oct 07, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Lines on camcoder lcd
the problem was solved automatically by connecting the camcoder to the pc which had the jvc software installed to it.
Aug 18, 2008 | JVC Everio GZ-MG21 Camcorder
JVC EVERIO GZ-MG22AS
I have JVC hard disk camcorder everio GZ-MG22AS with 20 GB hard disk drive which is full now, tried to copy it in my pc with its USB but it cannot be done?!
Hope you can direct me what to do so.
Thanks
Aug 03, 2008 | JVC Everio GZ-MG21 Camcorder
Recording problem
how do i use the lighting of my camcorder
May 09, 2008 | JVC Everio GZ-MG21 Camcorder
SONY DCR-HC39E loses it drivers
i buyed jvc GZ-MG 21E 20GB camcorder but lost its software onvery first day.now its one year i can't connect the stuff to my computer whenever i do so it shows "the device connected is not recognozed".i had enquired to us support center but no positive reply.i want to un load all the stuffs from the camcorder.
i got one of its software from dubai but still it does't work.please assist me in this problem.there is no support center in india .if it is please let me know.u can mail me at [email protected] .i'd buyed this stuff from nairobi airport.
Dec 03, 2007 | JVC Everio GZ-MG130 Camcorder
JVC Everio GZ-HD7 Camcorder Logo
52 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
