Question about Samsung VP-DC161 DVD Camcorder
Hi , i have got a samsung dvd camcorder recorder VP-DC172W and was trying to finalise a disc when the camera shut down on its own. i have tried several times to switch it on but its not responding. if you put it on charge u see the green blinking light on the side which shows its charging but i cant switch it on. please help
Posted by badu_terry on
Dwain Schmidt
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Hi , Your going to have to Hard reset it , I believe if you hold down the power and play mode buttons at the same time it should kick in for you. Google it I had a similar issue with one of my cameras about a month ago but its all good. Just about ant device has a hard reset combination , good luck
Posted on Nov 24, 2017
1 Related Answer
Anonymous
SOURCE: Disc error problems - Samsung VP-DC172W
The problem i think is from the Camera. But if you are a bit technical and have a T.V tuner card in your P.C what you can do is connect your camera to the pc tv tuner card with the A.V wire provided. With the software of your tuner card (if you don't have download Ulead Video studio or buy it) you can view and record your videos to your hardisk, then you can burn them to a DVD disk. if you have any questions you can e-mail me on [email protected]
Posted on Jan 03, 2010
I have a Samsung DVD camera recorder (model number VP-DC171Wi). I have recorded some footage on it and would like to view it on a tv/computer. I have gone through the finalising steps, a message pops up on...
There is a problem with the units firmware and thereby not writing the disc information correctly. This can be fixed by download and installing the latest firmware update.
You can find the firmware update at this link. You MUST choose the first listed update (size 0.39 mb) as this address the compatibility issue with particular discs
http://www.samsung.com/us/support/downloads/SCDC164
Here is the installation instructions for installing the firmware:
http://downloadcenter.samsung.com/content/FM/200607/20060713105015390_DVD_CAM_Firmware_update_manual.pdf
Sep 23, 2011 | Samsung SC-DC164 DVD Camcorder
My camcorder will not give me an option in disc operations to finalise a disc which I recorded on (which I did initialise before starting- I have also tried it on another disc, initialise, record etc) I...
Are you using the AC adapter when trying to finalize? You cannot finalize using battery power only.
Link to your manual:
Canon DC210 Manual
(What format discs are you using?)
Instructions for finalizing begin on page 61.
Hope this helps.
Thanks for using Fixya.
Mar 11, 2011 | Canon DC210 DVD Camcorder
Oct 21, 2009 | Samsung Video Cameras
I have a samsung vp-dc171w mini dvd recorder. I was told at the time of purchase that the disc would replay in a dvd player but none of mine play it. Is there an adaptor or something needed for it to play...
If your using DVD-RW make sure you format it in video mode. Do your recordings then when you want play them back on a dvd player you have to finalise the disk in the camcorder first.
If you want to continue recording you will have to un finalise the disk.
Aug 23, 2009 | Samsung VP-DC161 DVD Camcorder
Viewing Discs on Samsung VP-DC161
RE; smasung DC 161(i) pal and possibly other models The reason why there is no disc message when there is definitely a disc is installed is because the disc programming has malfunctioned, Its because of Samsungs poor design, after powering up the camcorder and inserting a disc, the disc will load and a green flashing light appears for a minute or two while loading if the Samsung camcorder is switched off while loading the camcorder will essentailly self destruct and their is no remedy, however that does not mean the Samsung is completely useless,the camcorder can record on a 4 GB SDHC(max 4GB) card using the switch from disc to memory card
Dec 16, 2008 | Samsung VP-DC161 DVD Camcorder
Digital cam vp-dc161
what ever size disc your using simply dont record the whole disc, example if you are recording on a 30min dvd-r only record 28mins then finalising will not be a problem.
Aug 29, 2008 | Samsung VP-DC161 DVD Camcorder
Disc playback
are u sure about the media type tat is supported in ur cam.
Jun 16, 2008 | Samsung VP-DC161 DVD Camcorder
Unable tp play discs on computor
Have you finalised the disc ? Go into the menu and where you format the disc there is an option to finalise. It should then play on your laptop. Hope that helps ;)
Jan 04, 2008 | Samsung VP-DC161 DVD Camcorder
Finalising
i bought a camcorder from currys model vp dc 172w back in october. i took it to las vegas to record my wedding. its recording fine but i cant finalize the disks. iam folowing the instructions from the book. on 1 disk its trying for about 30 seconds then is saying disk error. the other disks i cant even get them to start running. can you help me please.
Oct 30, 2007 | Samsung VP-DC161 DVD Camcorder
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Open Questions:
english/ Samsung VP-DC161WBi. Has included, has written down video, all in was normal. But having rolled the camera once again the screen has not joined. After inclusion the screen dark with a light horizontal strip in the middle, the disk is not untwisted, the chamber does not react to buttons. Prompt, how it is possible to solve this problem in what it, can business in insertions or a power unit? The guarantee at the chamber left. If business in insertions advise please where it is possible to download it. Thanks!!! на русском/ Samsung VP-DC161WBi. Включил, записал видео, все было в нормально. Но включив еще раз камеру экран не включился. После включения экран темный с светлой горизонтальной полоской посередине, диск не раскручивается, камера на кнопки не реагирует. Подскажите, как можно решить эту проблему, в чем она, может дело в прошивки или блоке питания? Гарантия у камеры вышла. Если дело в прошивки посоветуйте пожалуйста, где можно ее скачать. Спасибо!!!
Dec 18, 2009 | Samsung VP-DC161 DVD Camcorder
Samsung VP-DC161 DVD Camcorder Logo
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
