Question about Belling XOU592 / XOU593 Electric Double Oven
Bottom oven and top oven not heating up - Belling XOU592 / XOU593 Electric Double Oven
Posted by b_osullivan2 on
richardable
    New Friend:
Does the grill work? even if it does you need an engineer. the cooker will need to come out of the unit and the wiring and controls will need to be checked.
Posted on Sep 15, 2011
Ignis AXL 905/IX oven and prob is food is cooking on top but not below. Two elements at top. Inner on when in oven mode, outer on in grill . Bottom of oven not warming evenly and burning top of food
Your bottom element is not working and that is why foods placed on top heat up but the undersides are not affected as much.
You need even heat on both sides of the food. Get a new element and replace.
Sep 06, 2015 | Ovens
Whirlpool akz161 top oven. The lower heat element is not working how do l access this as l need to fix it myself
open door if you can see screws at element ends remove them and change or you will have to do it from the rear
Nov 16, 2013 | Ovens
My oven cooks everything on the top, but not as much on the bottom. The bottom element gets red, but, I'm not sure that it gets as red as the top?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | GE JKS05 Electric Single Oven
Top oven does not heat-although bottom oven is ok.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Belling XOU592 / XOU593 Electric Double Oven Logo
167 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Harrie
Are you a Belling Oven Expert? Answer questions, earn points and help others
