SOURCE: Canon Pixma ip4200--
I read somewhere that if the printer receives instruction from the PC that it requires black only printing (e.g. a letter in Word) then it will use the 5PGBK tank. The 8BK tank is used with the other colours in photo printing only. If you check the greyscale option, it will use ink from the 8BK tank and mix with the CMY colours to print, but I have not tried this out.
Good luck
SOURCE: I have an HP PSC
Try removing the printer then reinstalling it. If you have a disc. I think they have discontinued driver downloads for HP PCS 1300 and 1400. Do not remove it if you do not have an installation disc.
SOURCE: Printing in Black
just take out the colour cartridge from the printer, then you will be able to print.
SOURCE: colour is printing but not the black
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: Prints only part of large documents
Normal
0
