Question about JVC CP6U Adapter
How to open jvc c-p6u cassette adapter? - JVC CP6U Adapter
Posted by canise_b on
Don V
    New Friend:
Change the AA battery. I did and the switch worked and it ejected.
I had no idea there was a battery involved.
Panel on left end
Posted on Aug 19, 2012
1 Related Answer
brian shevack
  • 902 Answers
SOURCE: I have a JVC C-P6U Cassette Adapter,I have not
the adapter is probably jammed you may need to use a little force for the switch also a little force to try and pry it may work without damaging it. please let me know if this helps if now i will glady do more research on it for you but this is what i found when i was looking up the adapter issue.
Posted on Mar 14, 2011
I have an ancient JVC GR-sxm320 can't find the Manuel and can't open the cassette door.
There are two reasons normally that the cassette door won't open when you slide the Eject button on the JVC GR-SXM320. One: the camera uses a powered eject feature. If the battery is low and the AC adapter isn't plugged in and powering the camera, this doesn't work. Two: if the LCD monitor screen is not open to more than a 60 degree angle, then there is an interlock that keeps the cassette door closed. This avoids the door hitting the screen. It's best to have the monitor at a 90 degree angle to the camera body when you open the cassette. Press Stop if there is a chance that the camera is recording to the current cassette.
JVC has the manual here: http://resources.jvc.com/Resources/00/00/97/LYT0465-001A.pdf .
Note: since the camera is older, check that the AC adapter is getting warm when it's plugged in and connected to the camera. This checks if the adapter is working. Check if your battery pack is good. If you have the BN-V856U battery pack, you need the AA-V80U charger to charge the battery. The charger that came with the camera will not work.
Third party battery packs and chargers are still available for the GR-SXM320. Use the manual to look up the part number and Google for the battery or use the camera model number to find available parts. For example, a replacement BN-V11U battery is available at Amazon and here: https://www.bestbatt.com/JVC-BN-V11U-BN-V12U-BN-V14U-BNV-V18U-Battery-p/bbbnv11u.htm .
I hope this helps.
Is a cassette supposed to fit in the cassette adapter
I think the VHS-C (compact?) cassette is suppose to fit inside the JVC CP6U adapter if that is what you're asking?
JVC RV-B550 Cassette/CD Boombox Hi there. Please
take off all the knobs and it should come apart
I have a JVC C-P6U Cassette Adapter,I have not used it for some time as there was a cassette inside I put it in my TV and played the tape which was great when it was finished I wanted to remove it and play...
How do i hook up my mp3 player to this car cd player
The only way to play an mp3 player through this head unit is through an adapter. You will need to go to Best Buy or some electronics store and buy a cd-to-cassette adapter. You just plug the adapter into the mp3 player's headphone jack and insert the cassette into the head unit. Let the cassette play and play your music through the mp3 player and boom, you have a mp3-capable head unit.
My camcorder is on a safeguard mode, how do i take it out of the mode
Please go further down on the message, you must see a numeric code, like 03, or 02. In case you'll see 03, open the cassette door(let it open until cassette come out) about 5 sec or more(make sure you have enough batt. charge or use adapter). Once ejected do not use that cassette again. Using new cassette and same thing happen, have your camera checked by the expert. Error code other than 03, you need to consult the expert. Hope it helps
2helpful
Jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
2helpful
JVC VHS Cassette adapter C-P7u
How to safely open Micro MC_90 cassette
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
My VCR is egecting the tape with the casstte adapter.
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
JVC CP6U Adapter Logo
Top JVC Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a JVC Camera Expert? Answer questions, earn points and help others
