The optical audio connection (the TOSLINK) only works when paired with the Component connectors. Now you are using the the Composite one so you must use the audio connectors associated with it, the red and white next to it; then select the VCR1 input when you want to use them.
The audio quality will suffer a little but it will most surely pass unnoticed in most of the cases.
Yes.
Then the problem is in the Sony, not the Denon. Since you can't use the Sony to play music and a video at the same time then just leave the TOSLINK in place and the only video connection should go to the tv directly. This way the image will be on the tv and the sound will come either thru the tv's speakers or from the Denon, at your decision.
OK. Don't forget to select the correct AV entry in the tv and the correct input in the Denon.
Thanks for the reply. So it should work if I disconnect the optical audio connection and use the red and white lines for a analog audio connection?
I tried this and unfortunately it did not work. Still no video. Any other ideas?
I will try that.
