My wharfedale DVDHD400 recorder works fine when except for when I connect it up to my 5.1 Speaker system through the coaxial input. The sound is crackly and jumpy to the point where it is not audible. Standard RCA output works fine, just the SPDIF. I've tried changing the settings to RAW/PCM and it makes no difference.
SOURCE: Wharfedale dvdrhd400 problems
posted by msladsy on Dec 21, 2007
Report abuse
When the initial set up ran for the DVD recorder it set the correct time and, I assume, the correct date.
However, I had problems with the display and went through various settings until I solved the display problem.
Unfortunately, during the process, which included disconnecting the power, the clock was reset, starting at midnight and 1st January. There appears to be no way to access the clock.
How do I get the recorder to display the correct date/time?
Mark
Comment by msladsy, posted on Dec 21, 2007
This solution may work for other Wharfedale DVD recorders as well as the DVDRHD400F.
Use your Setup button to acces the 'Setup' menu.
Choose the 'Preferences' menu.
Choose 'Factory Defaults' and click on 'OK'.
The recorder will restore the factory defaults and the first screen it takes you too is the 'Initial Setup' screen where it asks you to enter the correct date and time.
Mark
Comment by msladsy, posted on Dec 22, 2007
May work on similar dvd recorders. Would help if Wharfedale included this in their users manual.
