Hi, For your requirement here is the remote configuration
below. Establish a data connection with a remote Multi Modem
product. Send
three remote configuration escape characters followed by AT and the setup password, and
press ENTER.
Example: %%%ATMTSMODEM. You have four tries to enter the correct password before being disconnected. If the
password is correct, the remote modem responds with OK. You
can now send AT commands to configure the remote modem. When you have finished
configuring the remote modem, save the new configuration by typing AT&W0, and pressing Enter. Type
ATO and press Enter to exit remote configuration.
You can then break the connection in the normal way. Setup: Multi?Tech
modems are shipped with a default setup password (MTSMODEM). Because anyone who
has an owner's manual knows the default setup password, for security you should
change the password and possibly also the remote configuration escape
character. To change the password Open a data communications program such as Phone Tools or
HyperTerminal. To
change the password, type AT#S=your new password ENTER. The password can include any keyboard character,
and must be one to eight characters long. The
modem responds with OK. The
new password is saved automatically. You can now either enter more AT commands
or exit the data communications program. The next time you remotely configure
the modem you must use the new setup password. . Changing the Remote Escape Character Establish
a remote configuration link with the remote modem as described in "Basic
Procedure." Type
ATS9=n, where n is the ASCII code for the new
remote configuration escape character, then press ENTER. Save
the new value by typing AT&W and pressing ENTER. Type
ATO
to exit from remote
configuration. You
can establish a high-speed connection to an external router, DSL modem, or
cable modem, and provide firewall and general security for your network.
Connect the provided Ethernet cable from the untrusted interface on the
NetScreen-5GT device to the external router or modem. You have to use RJ 45
connector to connect them. To
establish a console session: Plug
the female DB-9 end of the serial cable into the serial port of your PC. (Be sure
that the DB-9 is seated properly in the port.) Plug
the male DB-9 end of the serial cable into the Console port of theNetScreen-5GT
device. (Be sure that the DB- is seated properly in the port.) Launch
a serial terminal program. (A commonly-used terminal program is Hargreaves
HyperTerminal.) Typical settings to launch a console session with your
NetScreen-5GT device are as follows: •
Baud Rate to
9600 •
Parity to No •
Data Bits to 8 •
Stop Bit to 1 •
Flow Control to
none At
the login prompt, type the default login name: netscreen. At
the password prompt, type the default password: netscreen. Change the password, set an IP address. You will find
detail configuration of ns5gt in its manual.
