SOURCE: Hello, Settings on my computer!
First you need to tell us which web browser used. And then check whether if Java is already in the Add/Remove list.
Since you have AVG Internet Security 8.0 , there is no need to install Norton now.
Also check whether you have Flash plugin and active X installed on your PC.
Let me know if you need further assistance.
SOURCE: I've been having problems with
Regarding the missing "solutioncenter.msi", try re-installing the software that came with your printer or all-in-one. This may require removing the printer software first. This answer was posted on one of the HP forums.
In the future, it will help if you include the model number of your computer and printer.
SOURCE: Pop up solutioncenter.msi. Fix this problem?
Copy and paste this address into your browser, download and install the Windows install cleanup tool. Open it up after installation and look for anything labled solution center and remove it. Be very careful not to remove anything else, restart your computer and the issue should be resolved, at least it worked for me.
http://support.microsoft.com/kb/290301
SOURCE: My computer won't start properly.. everytime I
Blue screen may come in different causes:
1. Due to a corrupted Operating system, in this case you need to boot your bootable OS CD and try re-installing again.
2. Due to a hardware problem (i.e CD rom, memory, or hard disk). In this case try to re-seat them back and try if it can boot normally.
