Jenn-Air JES9860 Electric Kitchen Range Logo
Posted on Aug 15, 2011
Clock-control *** 100-00695-20 does not light or report anything, but the oven works okWhat part do i need
2 Related Answers
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 09, 2008
SOURCE: lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Anonymous
  • Posted on Nov 22, 2009
SOURCE: Do you know where I can get a Oven control
Found a panel from a company in CA...
I went to bake a lasagna turned to knob and noticed the oven light didn't come on
Question moved from Audio category to Heartland Range.
Sounds a bit like the oven timer is set. If not, turn off the power at the switch or breaker for 10 minutes. If that doesn't work, it could be anything, element, knob or control board so you will need a service call. They are a strange looking beast!
https://fireplaces-rochester-ny.com/wp-content/uploads/2019/04/Classic-Dual-Fuel-Range.pdf
3answers
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
1helpful
The electric circuit breaker kicked off and when it was reset, we are unable to get anything with the oven to work. the time comes on at 12:00 and then it starts beeping and a f 1 light appears
with kenmore F1 is a power failure in side the clock control
your whole clock will need to be replaced
go to www.appliancepartspros.com
type in your model number and look in the control section
Admiral Electric Oven Control Panel Issue
that is a part number to the clock assy, assuming you have 110v to L1 on back of the clock and no display , that s a preyty safe bet youll need to replace that clock assy
GE JT930 Electric Single Oven Problem not working
power controller board inside control panel upper right side, normally gets trashed with power surge from utility company power issues
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
1helpful
3answers
Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
[email protected]
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
