Question about Allen & Heath AH ZED 436 32 microphone/Line, 4 Bus Live Sound Mixer with USB Interface
I would like to buy a case for The Allen & Heath ZED-436 is an audio mixer that gives you 32 mono inputs plus 2 dual stereo channels. Which one do you recommend that can fit it well.Please send me email on [email protected]
Posted by shamias on
Fred Yearian
  • Allen & Heath Master
  • 5,603 Answers
Cases are being sold on Ebay, new, from several sources, and if you can't find one specifically listed for your unit, contact the sellers as they custom build them. That is a big unit... expect to pay around $150 to $200 for an ATA type case for it.
Here is an example for a Heath/Allen 420. http://cgi.ebay.com/ATA-CASE-ALLEN-HEATH-ZED-420-ZED-420-ZED420-MIXER-/400127078772?pt=LH_DefaultDomain_0&hash=item5d296eb174
I have bought from them before myself and there are others on Ebay so shop around... You can contact the companies and ask for a specific one and DO compare the size to your unit that they specify as all the companies do not accept returns...
Posted on Aug 15, 2011
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Hi i have an Allen and Heath ZED 22 with no onboard effects. I would like to use an external Behringher unit but am having difficulty in connecting the processed signal back to the mixer. i would like to...
Send audio from board via the "Aux1 Out" to the input of the effects unit. Now connect the output of the effects unit to "ST1" and control the amount of effects to each channel via each channels "Aux1" control. Adjust the Aux1 controls in the output stage (controls on the right side) for proper levels.
Older boards called this connection "effects send" for the output to the effect, and "effects return" for the effects out back to the board. The better choice was to use "effects send" into the effect but connect the effects output to an unused channel on the board. Using this scenario allowed EQ adjustments to be made before mixing it out to the amps and speakers.
Oct 01, 2013 | Peavey XR 8600D Powered Mixer
Stereo channels do not collapse to mono.
Unfortunately, behringer is not helpful in most cases.
I suggest selling the unit and buying a better product, like mackie.
Mar 31, 2017 | Behringer Europower PMP1680S 1600-Watt...
I purchased a brand new zed 436 on the 26th may 2011. However, all the faders except 1 feel like they have sand or somthing in them and the power supply fan is quite loud, what should i do, yours in...
If the faders are not SERVO driven they should not be rough. Sometimes they have slot sealing plastic covering the groove of the slider that may give some drag. As to the fan, the unit looks like it has a small fan which tend to be noisier than larger ones. Some fans are throttled by sensing temperature. Make sure the air flow is free and not occluded by cables or cabinetry.
Jul 22, 2011 | Allen & Heath AH ZED 436 32...
Hi there. When I power on the mxer it blinks all the signal light and the power light with the sound level indicator repeatedly untill i turn the unit off, I cannot use the mixer and would like to know...
Make sure ALL interconnected equipment is powered by the same receptacle or power conditioner. Do NOT use separate recptacles at opposite ends of a romm for example. Run power extension back with your snake. There may be a failure in the unit. Since it is so new, exercise your warranty... do NOT risk voiding the warranty. Do verify that your power is clean.
May 13, 2011 | Allen & Heath AH ZED 436 32...
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
Where on a 16:2 allen heath wizard would you hook up a 482i sonic maximizer?
The answer all depends on what you want to achieve.
  • If you just want to enhance the sound of 1 or 2 instruments / voices you could take a signal out from an individual channel on your mixer using the direct out and insert jack sockets on that channel however this may make it difficult to control in conjunction with teh E.Q. controls on that channel as the Sonic Enhancer would be pre-fade and pre E.Q.
  • Alternatively you could send several mixer channels of your choice through the Sonic by using one of the sub-mix outputs to give a feed to the Sonic, returning it to the main mix either via a couple of spare channels, or the paired stereo inputs that are only routed to the main outputs.
  • Thirdly you could use one of the auxiliary sends to allocate different levels of signal from any number of channels to the Sonic. These are normally used to supply a separate mix to on-stage fold-back systems, monitors etc. Here I would use one of the 2 post fade ones rather than the pre-fade - to avoid negating what you have set on the main mixer e-q (tone controls)/. One advantage of this option is that it allows you to only enhance part of the signal from a particular channel and to allow part to bypass the Sonic without enhancement. I think that this would be my preferred option unless all the auxiliary feeds are needed for other purposes.
  • Lastly you could just put the Sonic on the main outputs of the mixer. This would mean that the same level of enhancement would be applied to the whole mix. As the Sonic Enhancer only has unbalanced (mono) jack sockets this later option does reduce the likelihood of you introducing unwanted radio interference to the system, compared to putting it at an earlier stage in the mix because, as the Sonic is unbalanced, everything else after it in the mix chain will also be unbalanced.
Feb 02, 2011 | Allen & Heath Allen and Heath WZ3144 14...
Hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
Jan 23, 2010 | Music
Allen & Heath AH ZED 436 32 microphone/Line, 4 Bus Live Sound Mixer with USB Interface Logo
280 people viewed this question
Top Allen & Heath Music Experts
Marvin
Marvin
ray gallant
Watching Him
Watching Him
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
