IBM ThinkPad T60 Notebook Logo
Anonymous Posted on Aug 14, 2011
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will make any difference. HELP!?????
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
478
Points
21
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
1helpful
Notebook Crashes to PowerOff state when lid is closed
Running intense program with the lid closed will cause a sharp rise in temperature making the laptop hotter than it should be leading it into a shutdown. The second issue, windows should be shutdown properly rather than closing the lid, this makes the operational system unstable and will cause files to corrupt eventually.
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
Screen won't come on when laptop powers on
1. Software
- Try Fn + F5 or something like that
2. Electrical
- Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
3. Magnetic On/Off Switch to detect of Close/Open Lid
- Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch)
- Workaround, start windows with lid at 30 degree angle
Toll Free: 877 407 9229
any doubts you can get in touch with the best pc doctor through
www.thebestpcdoctor.com
Im running a external MONITOR. How can keep windows running when I shut the lid to my laptop? thanks
Windows XP:
By default, all laptops either go on standby or turn off to save precious battery, but you can override these rules from the Power Options (XP) in your control panel (Start > Control Panel > Performance and Maintenance > Power Options) and click on Advanced Tab and override the settings according to your preference.
I prefer "Do nothing" while closing the lid. Although this is real simple, few of us might not know it. I
Windows Vista/7:
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the "Power Options" dialog box's "Advanced Settings" tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for "Lid close action" by selecting a new option from drop down menu for both On battery and Plugged in. do-nothing-lid-close-281x300.jpg Based on own preference, it's possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  7. Click OK button.
Start menu wont show up
application softwares &system software in start menu
2answers
Software problem
Does this happen every time you download something from the internet?
Has the computer turned itself off while doing anything else?
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
740549c.jpgBased on own preference, it’s possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  1. Click OK button.
How to Disable Notebook Computer to Stand By or Hibernate on Closing Lid in Windows XP
  1. Log on to your computer as an administrator. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
e461aeb.gifAgain, any other settings such as Stand by and Hibernate can be set based on own preference.
  1. Click OK button.
Let me know if this helps - if not - PLEASE, further clairify so we can continue to find a fix for your problem....
2answers
Logging Off and won't come back on what to do
You can shut it down hard (by holding the power button until it shuts off), wait at least 10 seconds (for your hard drive to stop spinning) then start it up and then try shutting down windows normally instead of just closing the laptop's lid. You can then go into user accounts and delete all accept for your Administrative account (even Guest account), and see if that cures your ills.
Good Luck.
Laptop shutdown monitor shut to soon / stuck in sleep mode
the problem is the power off sensor ... this is a sensor to shut the monitor of if u close the lid (monitor) so it seems like that this sensor is still on the closed status so try to find it then see if it's a mechanical try to move it with your hand and if it's an electrical try to but a light on it .... if it work please rate me!
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
