Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Good Afternoon
On either side of the EasyFix base you will see a small square opening with the yellow IsoFix point showing through it. Take a flat head screwdriver and slide into this hole facing toward the front of the car and gently push the screwdriver handle so it ends up facing the rear of the car - this should unlock the IsoFix mechanism. You'll need to do it on both sides if both sides are stuck.
If this doesn't work, or once you have done this, take the base back to your retailer with your proof of purchase if it is under 2 years old and they will be able to assist.
Posted on Aug 22, 2011
Do you have a photo of this opening as we have the same problem but can't see the area you are suggesting.
Thanks in advance.
Posted on Jan 08, 2015
