HP Photosmart 7850 InkJet Printer Logo
Posted on Aug 14, 2011
Red light is flashing and will not print - HP Photosmart 7850 InkJet Printer
Epson R265 - both red lights flashing fast, and simultaneously
When your Epson printer's print head is clogged , then the red light for your ink and paper out is blinking. In this movement, the printer print head is blocked due to foreign objects or jammed paper.
Fix the Epson printer red lights blinking error with simple steps.
1helpful
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
1helpful
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
HP 4L stopped printing. Red light flashes
May be some ilegal process, May be paper not in tray, find it
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
6helpful
2answers
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
1helpful
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
11helpful
2answers
Kyocera Ecosys FS 920
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
k24674
Grand Canyon Tech
Grand Canyon Tech
