Question about Fuji FinePix Z3 Digital Camera
Can i charge with out cradle finepixz3 - Fuji FinePix Z3 Digital Camera
How do I get the craddle to turn on
It depend of model of your cradle:
If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda.
Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda.
The driver need to be installed before connect the cradle to computers USB-port.
Mar 03, 2014 | CIPHERLAB 8000 Series Handheld Mobile...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Replacement USB charging cradle for Logitech Mouse
It sounds like you are talking about a wireless unit, and I am going to assume that it has stopped charging.....Try this first before you purchase a new cradle for it....Take a pencil eraser and clean the terminal prongs on the cradle, just as if you were erasing on paper, then do the same to the terminal plates on the mouse....
Sep 27, 2009 | Computers & Internet
Battery in cradle don't charge
Two reasons. Either the battery is dead or the cradel's charging circuit is faulty. But the red light shows that the cradle is fine. SO, the axe falls on the battery.
Sep 19, 2009 | Casio Exilim EX-S880 Digital Camera
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Compaq Ipaq not Charging
As I understand it, the basic cradle that comes with the Compaq Ipaq 3870 does not charge. If I were you, I'd either seek out a charging cradle or google the instructions for modifying your cradle to charge. Good luck...
Dec 02, 2008 | Compaq iPAQ H3760 Pocket PC
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
MC50 won't boot with battery attached
Be sure the Battery is in the "LOCKED" position, with the lever all the way to the right.
Jun 29, 2008 | Symbol MC50 Pocket PC
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Fuji FinePix Z3 Digital Camera Logo
24 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
