Question about Sanyo DP32746 32 in. LCD Television
I have a Sanyo DP32746 that has no picture or sound and the power LED does not turn on. You can hear a click on the power supply board when the power button is press either on or off. The only thnig that I can see that might be a problem is capacitors C690 and C647 are slightly swelled (both 820 uf electrolytics 200V). Is it worth trying to repair this unit?
Posted by ffrola on
Noel Jucutan
  • 998 Answers
Yes replace those capacitor but observe the polarity feel free to send feed back good day and best regards.
Posted on Aug 14, 2011
Sanyo dp32746 32in.... is making clicking noise when you try to turn it on ..... no picture on screen or sound practically dead. Took back off it is clickin around the bottom left corner of the board that...
hi
the common procedure is to replace 1 or 2
capacitor on the board i would suggest to take the board out and take it to your local repair shop and they'll know what to do
Sep 30, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
When i hit the power button it clicks like it wants to turn on but the screen does not come on
It sounds like the back light inverter board may have gone out, or it is not getting 24vdc from the power supply module, those are the two places to check.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sanyo+DP32746+
Jan 06, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
Won't power up
contact the customer care.
Oct 04, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 - No picture or Sound
Damage is in the power supply. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist. If your set is to old for warranty service, and you wish to repair yourself, check out the site www.shopjimmy.com, they can provide functional pwb's for a fraction of the cost of new.
Jul 14, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 Power Supply
Yes replace the power section of the tv.
Jul 13, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
Top Sanyo Televison & Video Experts
Mike
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
